Old 02-01-2008, 07:38 AM
OverClock OverClock is offline
Angry How do you get rid of video preview thumbnails?
I have previously asked how to get rid of them and the steps offered did remove them when Sage is not running in service mode, but in service mode they are still there. Also with the latest version of Sage the icons that replace the thumbnails animate and scroll if there are several videos in the library folder. Is it possible to have no icons or thumbnails and to stop the scrolling of said icons and thumbnails when there are multiple video files in the folder?
Video thumbnails are pointless. All they show is commercials or credits or some other randomly useless image that conveys zero information. They constantly slow menus and cause stalls and stutters as Sage searches through dozens or hundreds of video files to find and extract the images for them. Also, with the default setting, thousands of jpg thumbnail files are generated and continuously build up adding to drive load, wasted space and drive fragmentation. I love Sage, couldn't live without it, but even a great product can have a bad idea. There is no point to thumbnails other than to look nifty and they are a constant drain on system resources.
Old 02-01-2008, 08:38 AM
Why not just disable all the animations?
Old 02-01-2008, 11:25 AM
GKusnick's Avatar
GKusnick GKusnick is offline
Did you repeat those steps on SageClient.properties after enabling service mode?
Personally I like the thumbnails. They don't bog down my system, and it's not hard to adjust the video_thumbnail_extraction_time_offset_sec property to get useful images. As for fragmentation and wasted disk space, a thousand thumbnails add up to a few megabytes; that's peanuts compared to, say, my web browser cache, which contains tens of thousands of files and hundreds of megabytes.
But if you don't like thumbnails, feel free to disable them; that's why they're optional.
-- Greg
Old 02-01-2008, 11:30 AM
If you disabled them in non-service mode, then do the same for service mode, but using sageclient.properties.
If you don't want the animations, there are some settings in Detailed Setup -> General -> Animation Options. Among them is one to turn off thumbnail transitions. (Those options used to be in the Customizations section & moved as of v6.3.8.) They now use the core animations system, so the animations should use much less cpu time, unless you have 3D Acceleration disabled.
Old 02-01-2008, 01:36 PM
NOTE: you can use my VideoEdit plugin to select the exact frame you want for the thumbnail without needing to edit the property file it doesn't use that property to generate the thumbnail.
STV: SageMC 16x9 Version 6.x (latest dev build) dflachbart SageMC Custom Interface 6112 04-04-2008 11:16 PM
Media Center Video Thumbnails Karen0302 SageTV Software 1 10-05-2007 04:14 AM
2nd problem I can't get to work. Imported Video thumbnails... mrrrl SageTV Beta Test Software 10 10-12-2006 08:33 PM
