Old 05-19-2008, 02:01 PM
Bacon2002 Bacon2002 is offline
STX-HD100 and PAL
Hi,
I've just ordered my second STX-HD100, I think they are great and I'm very happy with the one I already have.
Being that I live in the UK my problem is that my main TV is (I think) PAL only (Sony Wega - CRT). Consiquently I couldn't get the picture to look right.
Is there a plan to support the PAL standard in the near future or does anyone have any advice that might help me to get my main TV to work properly with a HD100.
Many thanks,
David
Old 05-20-2008, 11:43 AM
bjkiller's Avatar
bjkiller bjkiller is offline
Cool
i do not think you will have anyproblem, most european TV has support for Multisystem. I have 3 HD Extenders in ISRAEL.
Dear Google, Please don't ruin SageTV for us!!
Sage Server: [s]8xDVB-S2 with DVBE4Sage on YES DBS Israel 4W (3 virtual tuners) ,[/s] 3 x HD300 Extenders; 3 x HD200 Extender; 3 x SageTV Client;
Old 05-20-2008, 01:41 PM
matt91's Avatar
matt91 matt91 is offline
I know nothing about PAL vs NTSC, but wouldn't the HD100 just reproduce whatever format the recording was in? If you're playing back a NTSC recording, it won't look right. But if you play back a PAL recording, it should be OK.
Or am i missing something?
Old 05-20-2008, 03:51 PM
Originally Posted by Bacon2002 View Post
Hi,
Many thanks,
David
Have you tried any of the suggestions in this thread? You probably have but I though I would ask.
Old 05-21-2008, 06:58 AM
chrik chrik is offline
How does the HD extender work in Denmark (PAL) with a Samsung LE40F86 one of the latest models. When will the extender be in a PAL version. Pls hurry :-)
Old 05-21-2008, 07:43 AM
starfire starfire is offline
Surely if your connecting it via HDMI or component then PAL/NTSC is not relevant as won't it be using 720p, 1080i etc ?
Ah, I see the HD100 only currently supports 720P50 as a default
Last edited by starfire; 05-21-2008 at 08:43 AM. Reason: reviewed the thread mentioned above
Old 05-22-2008, 02:09 AM
Anyone from Denmark or other european countries who has tried the HD Extender? It sounds very interesting
Old 05-22-2008, 04:15 PM
KrisAcker KrisAcker is offline
It's working fine in Belgium (PAL) connected to my 5 month old Sony HD tv (1080) via HDMI.
Old 05-23-2008, 03:50 PM
rtengvad rtengvad is offline
Just got my HD100 today and I can confirm that it is NOT working with my old B&O TV (pal). Either via composite or S-VHS that are the options I have so far.
A bit disappointing actually. I should have read that thread earlier. Now I hope that firmware update will be available soon so I can use my HD Extender. For now I'll have to put back my old Hauppauge MVP.
Rasmus
Server: Win7 SageTV v7.1.9 GA-MA785GM-US2H Athlon 64 X2 BE-2350 2 Gb RAM 4x 1Tb WD RE-2 GP in RAID5, Adaptec 5405 Raid controller 2x firewire DVB-C FloppyDTV C/CI, 1x TechnoTrend CT-3650 CI via the LM Smart DVB Recorder plug-in.
Clients: HD300 to a Samsung PS50C7705 (PN50C8000) via a DVDO Edge HD200 Placeshifter
Remote: Universal Remote Control MX-980
Old 05-27-2008, 05:36 AM
Please hurry with the PAL support :-)
Old 05-27-2008, 07:56 AM
mickm mickm is offline
I really don't understand Sage's slow support on adding something so basic, it's extremely annoying.
If it's possible to add a line or two to a configuration file to allow the necessary modes, why is it taking so long to make it possible for these modes to be selected as default or even better still, native switching based on the source?
For those who are saying "What's the problem?", have you ever watched live PAL tv with NTSC frame rates? It's horrible and shows up as extremely jerky especially on panning shots. The most blindingly obvious and annoying place to see this most awful 'feature' is on a news channel with a scrolling text update across the bottom of the screen. It's headwrecking.
Come on Sage, get your finger out! It's been months now without even a promise that it will be included in the next firmware update.
Old 05-27-2008, 09:16 AM
Yes, please hurry with PAL so I can use my new extender. For now its been stored in the basement. Not great!
Rasmus
Old 05-27-2008, 09:20 AM
jaminben jaminben is offline
I'd also like to see PAL support for the new extender asap. Its not a massive problem but its still annoying having to push a button on the remote.
Old 05-27-2008, 12:01 PM
PeterC PeterC is offline
I have set mine to enable "Native Output Resolution Switching" and it now automatically switches to 50Hz when you first play a PAL video, I think this started working with the recent beta update.
You still need to add the extra resolutions to the properties file.
I dont know if this will work for everyone but it works perfectly with my setup.
Old 05-27-2008, 12:10 PM
But these resolution properties. are they only working with hdmi? I'm not sure I quite understand.
Rasmus
Old 05-27-2008, 03:07 PM
Originally Posted by rtengvad View Post
But these resulution properties. are they only working with hdmi? I'm not sure I quite understand.
Rasmus
I'm not sure, they are HDMI in my case.
Old 05-28-2008, 12:21 AM
So what you are saying PeterC is that you can work around the missing PAL support by inserting the right lines in the properties file?
Rasmus
Old 05-28-2008, 02:29 AM
Rasmus
Yes, that is the case but the problem lingers. You must change the output resolution manually every time you change a channel or every time Sage starts a new recording as it reverts back to NTSC...
Old 05-28-2008, 03:02 AM
Mine used to do this, but it now selects my 1080P PAL setting.
I am using the latest beta and extender firmware updates.
Old 05-28-2008, 03:44 AM
Thanks guys. But to cut it in stone for me, could you please help me specifying the line(s) I have to put in the properties. My tv is a standard 4.3 and I connect via composite or s-video. Most of my recordings are SD but I have a few HD-movies recorded.
I guess this should have no effects on my recordings since my tuners just grab the digital stream (in pal).
Ohh, and i final question. Will this mean that the server has to transcode all files to be viewed on the HD100?
Rasmus
