Old 07-21-2008, 12:15 AM
markdm markdm is offline
DirecTV D12-300 STB Help
Hi,
I'm new here, and this is my first post. I did a search and couldn't seem to find the info I need.
My problem is this: I just got direcTV installed, I have the D12-300 STB, I can watch TV, but can't change the channel unless I use the remote for the DTV STB, which then makes the guide useless and I can't record anything except the channel I left the STB on.
Is there a way to control the channels with my wintv PVR1800 & sageTV 6.3.10? or one of the beta's??
If there are links on how to do this, that would be great as well. I'm very new to the PVR/DVR setup on my computer, so please explain if you can.
Thank you...
Old 07-21-2008, 03:33 AM
Buy one of these: http://www.patersontech.com/products...ranslator.aspx
If you need a serial port and have a free USB port, I would buy a Bafo BF-810. It uses the same driver as the PatersonTech Device.
After installing this, you will be able to change the channels via serial tuning.
B
Old 07-25-2008, 11:27 AM
B
Thank You bcjenkins,
Thats exactly what I was looking for, something simple and easy to plug in. Funny thing is, I called DirecTV and asked them about the USB connection on the back of my D12-300 and they told me it was for future use, wasn't hooked up yet, and had no other info on it at this time.
STB and Cabling to maximize SageTV Media Extender Experience johnwmreed Hardware Support 3 06-17-2008 03:19 PM
HIP 1600 Remote/Changing Channels on DirecTV STB txcde Hardware Support 1 10-17-2007 04:31 PM
Controlling a STB?? jefnert Hardware Support 3 10-06-2007 08:29 PM
Directv D12 Receiver and Direct dll compatible??? wags119 Hardware Support 0 06-05-2007 08:07 PM
STB not changing channels? Steve52 Hardware Support 0 03-31-2006 05:46 PM
