Old 08-28-2008, 04:00 PM
bluenote bluenote is offline
Fixing my old hauppauge remote?
My remote that came with my pvr-350 seems to have given up the ghost,
but I still want to use the remote receiver that came with the 350. (Unless someone has an easy to configure relatively inexpensive alternative?)
Anyways, I'm sortof guessing that it may be the LED that has gone in the remote. Can anyone suggest how I might be able to confirm this, and/or to fix it? Will any IR LED work as a replacement?
The way I've confirmed its the remote and not the receiver is, I have a USB UIRT on another machine, and this remote doesnt make the red light come on, while others do.
thanks for any suggestions
(Suggestions on where I can buy an exact replacement are also welcome)
Cory
Old 08-28-2008, 04:58 PM
Humanzee's Avatar
Humanzee Humanzee is offline
if you have a low lux or night vision security camera you can point the remote at that and you should be able to see the LED's light up/flahs if they are working.
Old 08-28-2008, 05:03 PM
There's always the obvious thing to check, just in case you haven't: the batteries.
Hauppauge sells a replacement remote.
Old 08-28-2008, 10:45 PM
matt91's Avatar
matt91 matt91 is offline
I've always been able to see remote flashes through my Cannon camera (point-and-shoot type)
Old 08-29-2008, 09:36 AM
Hey guys
Opus: the batteries are fresh and confirmed good. Thanks for the link, for $10 it may be my best option, although I hate ordering stuff through the border because its always a hassle it seems. (In Canada)
Humanzee & Matt -- thanks for the tip, I will see if my point and shoot can do the trick for this.
Can anyone comment on replacing the IR LED with a random one from radio shack (I think they only have one type there anyways ... and they are sold 'matched') ... since I have the remote apart and the LED unsoldered at this point I wouldnt mind finishing the job just for the satisfaction, and its actually more convenient for me than waiting for stuff to cross customs.
Unfortunately I don't know anything about IR LED types and whether this is likely or not to work. Can anyone comment?
thanks,
Cory
Old 08-29-2008, 12:10 PM
Humanzee's Avatar
In my experience LED's just don't fail. I think its more likely some corrosion on the circuit board one of chips isn't working to spec anymore bad button or wire connecting the batteries etc.
If you get a camera working that can pick up the IR light given off by another one of your remotes you can likely check the LED in your Hauppauge by jumping it with a AA battery. Remember it is a diode so try both polarities off your battery.
Also, you can try finding a battery operated AM radio and place it adjacent to your remote. A working remote will usually put off a series of rhythmic static chirps when you press a button.
Old 08-30-2008, 12:52 PM
thanks humanzee. I agree with you on the probable source, but changing the LED was about the only thing I could do myself so "it has to be that"
Hopefully I'll get to try this out sometime today.
Great tips btw, thanks
Cory
Hauppauge 45 button remote. Some buttons not working. John@TunerUK Hardware Support 1 12-10-2007 10:59 AM
Linux and Hauppauge PVR 150 Remote gossman SageTV Placeshifter 0 06-08-2007 07:25 PM
Bought new Hauppauge remote, now having problems supernoob Hardware Support 1 02-26-2006 01:10 PM
Hauppauge remote with an Irman receiver? dnlmln Hardware Support 2 02-25-2006 10:54 PM
Hauppauge remote - same key, different results Ken C Hardware Support 3 12-13-2005 10:29 PM
