Old 12-13-2008, 02:59 PM
bbwebb bbwebb is offline
HD200 & ReadyNAS - File No Longer Exists
I'm having an odd problem with my HD200. When I'm in standalone mode I cannot play any videos that are on my ReadNAS NAS server. It will play music and pictures that are in the same shares, but whenever I choose a video I get the following error:
(ERROR -2): Files selected for playback are no longer on the disk
To be clear, the files show up in when browsing the directory. But when I select them and hit play I get the above error. I've verified permissions and also verified that files that I can play have the same permissions that file that I can't play have. I have tried .iso, .mkv, and .mpg files without success. I am not having any problems playing files that are on other network volumes (i.e. my Linux box, or directly from my Sage servers recordings directory)
One other data point, the files play fine when accessed through Sage (i.e. not in Standalone Mode).
I'm also running the latest beta firmware.
Any thoughts?
Bill
Old 12-13-2008, 04:47 PM
Did you allow the guest account access specifically t that share?
Old 12-13-2008, 08:05 PM
rswoods rswoods is offline
I have the same problem in standalone mode. I can see them, but if I go to play them , I get the "Files selected for playback are no longer on the disk". The Guest account has read & execute privileges on all the files. I haven't worried too much about it because they play fine while the HD200 is in extender mode.
Old 12-14-2008, 05:34 PM
For reasons that I cannot explain I was able to resolve the issue by going from "Share" level security to "User" level security on my ReadyNAS.
Bill
Old 12-20-2008, 09:15 PM
richgnoe richgnoe is offline
Same here
Server:
2 PVR 150s w/ 1 RCA DirectTV tuners using serial control and 1 Cable Tv Connection. 2 AverMedia 180 HD OTA capture card picking up locals in HD. AMD 64 Athlon 3000+, 1 gig RAM. 6x 250 Gig
Old 12-20-2008, 10:05 PM
QueOnda's Avatar
QueOnda QueOnda is offline
I've had the same problem but I have a previous firmware. The read latest firmware on the HD200 lets you set a username and password. See Item # 4: http://forums.sagetv.com/forums/show...5&postcount=19
Don't know how to use it and don't know if it works. I haven't tried it yet.
Old 05-21-2009, 10:26 PM
mbowe mbowe is offline
Fix ReadyNAS Access
Bill
Thanks Bill, this worked for me as well.
H/W: 3GHz Intel Quad Core Duo, 8Gig Mem, Dual HDHR, Hauppauge1800 & InstantHDTV
S/W: Windows 8.1, Java 7.75, SageTV 7, OTA Only
Extenders: HD200/HD100 & MediaMVP
Old 05-23-2009, 05:03 AM
mike_ac mike_ac is offline
We had this issue pop up, as well, but found that upgrading to the 050509 beta firmware resolved it.
Specifically, our ISO files burned with DVDShrink showed up as MPV files, but when played, we received the error message above.
We use a Thecus 4100Pro server, so the upgrade was the real key... Files then showed up as ISO files, and all was good.
Old 05-23-2009, 08:02 AM
Slack's Avatar
Slack Slack is offline
The current beta software will allow you to access ReadyNAS shares WITHOUT having to change your security from share to user.
I was reluctant to change my ReadyNAS' security, and although it took a little while Sage stepped up and fixed it....
[FIXED] HD-200 Arrived Today: Not a good start....
Old 07-18-2009, 01:41 PM
loonsailor loonsailor is offline
I can't get to most of the content on my ReadyNAS. I can see some folders, but not most of them, even though they all have the same permissions. The media share has five folders - Desktop, Music, Pictures, torrents, Video. Inside Music, there are two folders, Eli & jerry, and a couple of random mp3 at the top level.
When I select Browse Device:myserver:ReadyNAS, I see Video, Pictures, Music, and Browse Folders. Video is empty, Music seems to have the stuff from Eli, but not jerry. If I select Browse Folders, I see torrents and Music, but not the other folders. If I select Music from there, I see Eli, but not jerry.
When I look at all of this via a cifs mount, everything is permission 777, owned by root. Default access to the media share is read-only, and I'm using user-level security.
How is the HD200 accessing the NAS? I've got cifs, nfs, afp, ftp, http all enabled, as well as the streaming services iTunes, readyDLNA and Home Media Streaming Server. Which of these is the HD200 using?
I'm running the newest beta HD200 software 6.5.18.1 / firmware 20090702-0. Also, the newest ReadyNAS firmware 4.1.6.
What should I try?
Automated VideoRedo (DOS batch files) grauchy SageTV Customizations 3 09-08-2011 10:01 PM
.ts file not showing up Milord SageTV Software 2 10-29-2008 01:47 PM
Getting a new .frq file recognized Dvid SageTV Software 12 06-10-2008 11:14 PM
SageTV V6.3.10 Release Candidate Narflex SageTV Beta Test Software 0 02-28-2008 06:07 PM
