Old 04-03-2009, 05:28 PM
vividweb vividweb is offline
HD playback with ATI 4670
I have an ATI 4670 in my main desktop and want to start using it for SageTV. I have only the Arcsoft software installed on the machine and it plays back HD-PVR recordings perfectly. However I cannot get good playback of H.264 content recorded with my Genpix DVB card. The files will playback perfectly using the arcsoft player (software that came with the HD-PVR) and using Windows Media Player, but stutter and are un-watchable in SageTV.
I have added the following lines into the properties file on the client machine:
videoframe/h264_video_decoder_filter=ArcSoft Video Decoder
videoframe/ac3_audio_decoder_filter=AC3Filter
videoframe/audio_decoder_filter=ArcSoft Audio Decoder HD
videoframe/audio_render_filter=Default DirectSound Device
videoframe/video_decoder_filter=ArcSoft Video Decoder
always_use_dshow_player=true
The drivers are using DXVA (with windows XP) as I"m getting very little CPU utilization when the files are playing. The file will play for a 30 seconds or so, then will stutter, then play fine again for a while. The CPU does not change when the stuttering starts. Anyone have any suggestions?
Sage Server: i5-2500K 8 GB DDR, 6000gb HDD, 4xHD-PVR < 4xBell 6141, Win7 x64
Client 1: HD-200, Panasonic 42PX75
Client 2: HD-300, Samsung LCD
Client 3: HD-300, Samsung PN50C550
Client 4: MS Surface Pro
Old 04-04-2009, 06:59 AM
SWKerr SWKerr is offline
Have you tried setting this to false?
always_use_dshow_player=false
Old 04-04-2009, 11:24 PM
yep. makes no difference at all.
Old 04-05-2009, 07:24 AM
Are you sure the DVB card is creating h.264 files? You can use something like tsMuxer to check it. If it is mpeg2 HD then you are playing with the wrong settings.
Old 04-05-2009, 08:39 AM
I am sure it is an h.264 file. Sage identifies it as MPEG2-TS[H.264 1080i].
Media info gives the following result:
Format : MPEG-TS at 7 647 Kbps
Length : 5 GiB for 1h 29mn 44s 156ms
Video #0 : AVC at 6 732 Kbps
Aspect : 1440 x 1080 (1.778) at 29.970 fps
Audio #0 : AC-3 at 384 Kbps
Infos : 6 channels, 48.0 KHz
Old 04-08-2009, 11:26 PM
have you used graphedit to see exactly which audio/video decoders your system is using to playback the files when not using Sage?
What version of Sage are you using? There is an updated mpeg demuxer in the last few beta versions that solved some playback problems for me (my issues were related to time sync when skipping through recordings). It may be worth trying the latest beta if you aren't already on it.
-Striker-
4670, playback
Need help with 1080i playback (Ati 4550 & Cyberlink decoder). Deinterlacing issue? Spartan SageTV Software 11 04-02-2009 07:06 AM
settings & decoder for ATI 4670 card xj-boonie SageTV Software 4 12-02-2008 01:37 AM
ATI to Offer HD Playback with Linux bjterry62 Hardware Support 0 09-02-2008 01:56 PM
Which ATI Card for HD Sage Playback djseto Hardware Support 1 03-09-2008 07:38 PM
Success in Playback with ATI AIW???? davedelite General Discussion 5 04-02-2003 08:39 PM
