Old 04-20-2010, 08:01 PM
medwynd medwynd is offline
How to move SageTV install to new path on WHS
When you install the addin it by default installs itself on my c drive which is a tiny partition and I would like to move it to my main storage but cannot figure out how since it never prompts me to put it somewhere else.
Do I just have to deal with it on c and change all the paths in sage for fanout and such to point to my main storage? How would I tell sage to change where wiz.bin is stored?
Old 04-21-2010, 08:08 PM
geogecko geogecko is offline
Are you really concerned about SageTV, the program, taking up space? I know a wiz.bin can get pretty big, say, several MB, but not that big... Or are you talking about media storage?
Media storage is setup in detailed setup, where you can specify any drive or directory you want. This will be the bulk of your data.
-Jason
Old 04-21-2010, 08:51 PM
If its only several MB then its not a big deal. I have just started using SageTV but I generally as a rule try not to keep files that grow dynamically on such a small partition.
Considering Move to WHS toricred Hardware Support 1 09-25-2009 06:37 AM
New WHS Install with Sagetv jorton SageTV Software 5 07-27-2009 09:54 PM
What drive for OS on a new WHS install? btrcp2000 Hardware Support 4 07-19-2009 07:53 AM
Really need help with new WHS install skitter SageTV Software 11 01-15-2009 02:10 PM
SageTV and WHS install spoonman1227 SageTV Beta Test Software 3 06-24-2008 02:12 AM
