Old 05-20-2010, 03:52 PM
Jimmi24 Jimmi24 is offline
List of Plugins in the Plugin Manager
Is there anywhere to find a list of all of the currently available plugins for in the plugin manager?
I would really like to know what is available before I make the plunge...
Old 05-20-2010, 09:14 PM
GKusnick's Avatar
GKusnick GKusnick is offline
The raw repository data is available in XML form here, but it's not very user-friendly.
Attached is a very simple repository viewer that attempts to render it in a more human-readable format. Unzip the file to temp directory and bring up PluginViewer.xml in a browser.
This is not a polished tool and I'm not planning to put much effort into maintaining or enhancing it. (But if the SageTV webmaster wants to use this as the basis for an online repository viewer, they're welcome to do so.)
-- Greg
Old 05-20-2010, 09:34 PM
Thanks a lot. I just wanted to make sure they had some of the essentials before installing the beta.
this is very helpful.
Old 05-21-2010, 08:03 AM
Zippster's Avatar
Zippster Zippster is offline
Some things may be missing temporarily as dev's either catch up to the beta or some take over abandoned plugins to update, all I can say at this point is, WELL worth any slight plugin inconveniences, the new Sage is AWESOME and I'm probably happier and even more in awe then when I first bought Sage years ago if that is possible. It doesnt seem to act like a beta at all either.
6.4.8s Plugin Manager Support? alijiwani SageMC Custom Interface 3 08-17-2008 06:22 PM
Concept? Integrated plugin manager? mike_15 SageTV Customizations 0 09-25-2007 10:52 AM
