Old 05-21-2010, 11:13 AM
nigfink's Avatar
nigfink nigfink is offline
Filter Folder Views?
I loved the feature in v6 that allowed you filter your imported videos by what folder they were imported by. It allowed me to sort my d/l'ed TV from my Movies (since both are imported videos). I know is used the following in v6:
<evalExpression>AddStaticContext("PathFilterExprs", new_java_util_ArrayList())</evalExpression>
<evalExpression>java_util_List_add(PathFilterExprs, "\\\\10.10.0.3\\external\\tv")</evalExpression>
<evalExpression>java_util_List_add(PathFilterExprs, "\\\\10.10.0.3\\media")</evalExpression>
<evalExpression>AddStaticContext("PathFilterExcludes", true)</evalExpression>
Is there something similar I can use to modify the SageV7.xml file? Without this I am forced to keep using the v6 xmls. I don't want to scroll though all those movies to get to my TV.
Thanks in advance!
Old 05-21-2010, 11:16 AM
Weren't you doing this within the Dynamic Menu plugin? That is not available for SageTV 7 beta AFAIK.
Old 05-21-2010, 11:20 AM
nigfink's Avatar
Yep, exactly. Hopefully something happens soon. I like the new UI alot, but can't use it as it is.
Looking for ideas for setting up kids views BarkOLounger SageTV Software 1 06-03-2010 08:24 AM
Multiple Recording or Guide Views? bbwebb SageTV Software 1 05-11-2008 08:42 PM
new display of folder views? ChePazzo SageTV Beta Test Software 2 12-09-2006 10:04 PM
