Old 05-23-2010, 08:17 AM
lamanmi's Avatar
lamanmi lamanmi is offline
Navigate to Sage Menu and/or Option Box From Java
I am looking for if it is possbile through Java code to tell the Sage UI to navigate to a specific menu and/or to bring up an option box in sage?
For extenders, ideally I would like the Java code to be able to tell the server UI or a specific extender to navigate.
Any help would be greatly appreciated.
Old 05-23-2010, 11:36 AM
GKusnick's Avatar
GKusnick GKusnick is offline
ExecuteWidgetChain() in the WidgetAPI can do this. You'll need the correct UI context for the client UI you're trying to navigate.
If none of this means anything to you, see the sticky posts in the Studio forum (where most questions about plugin development should go).
-- Greg
How to add a directory? Can't find menu option gunzour SageTV Media Extender 1 02-26-2010 03:27 PM
Best setup for WHS in a separate box from sage box? btrcp2000 Hardware Support 8 02-10-2010 11:11 PM
Save option on Stop menu jelwood SageMC Custom Interface 0 12-05-2008 07:24 AM
Suggestion - "Set top Box Contol" option for live tv hi_tech_guy_18 SageTV Software 1 11-03-2007 01:13 PM
Media Extender Server menu option mrblack SageTV Media Extender 4 02-19-2006 01:04 PM
