Old 05-24-2010, 05:01 PM
alton987 alton987 is offline
Metadata Tools for SageTV7 - Error
I am a total noob with sagetv, been using MC forever. I installed the plugin via the setup menu. When i go to installed applications is says failed right next to it.
Where can i start trouble shooting this?
Old 05-24-2010, 05:17 PM
Peter_h Peter_h is offline
This is a known bug.
Please see this post.
Old 05-24-2010, 05:42 PM
Error
When I looked I had the old version of the jar file the post you linked to is talking about. I deleted the file and it stills said failed after restarting sagetv.
I then deleted every plugin and only installed the Metadata Tool.
I now only have the new jar but it still saying failed.
Old 05-24-2010, 05:57 PM
@alton - perhaps you could restart sagetv, and then send the log file called, sagetv_0.txt in the SageTV home directory. This error may be new, and unrelated to the previous error that was mentioned, since it does look like you have correct versions installed.
I suspect the issue is a conflict with other jars, other than the sagex-api jar.
You can email me directly at metadatatools at gmail dot com.
Old 05-24-2010, 06:05 PM
file
Sorry I'm a noob, Is the log file in "C:\Programsfiles\sagetv\sagetv\" I am seeing some log files but nothing that matches that 100%.
This is a fresh install on Win7.
Old 05-24-2010, 06:34 PM
That does seem like the directory. in this directory, there should be a Sage.properties, and JARs/ directory. SageTV normally writes it's log file there, called something like, sagetv_0.txt.
Also, could you email me a list of all of the jar files that you have in the JARs directory.
And, you mentioned this is a clean install. You you've installed sage7, then bmt, and it failed? It's not an upgrade from Sage6?
Old 05-24-2010, 06:42 PM
Yes I have never installed Sage6 before.
Here is a screen shot of the dir, do you see the log file you need?
http://i47.tinypic.com/91cq4w.jpg
Last edited by Opus4; 05-24-2010 at 06:43 PM. Reason: image too wide to post inline; changed to link
Old 05-24-2010, 06:47 PM
ma22xx ma22xx is offline
Is this a 64 bit version of windows? If so you might have a program files(x86) folder with sage in there. The other thing I've seen with windows 7 is that if you didn't turn off UAC before installing sage then any files created by the app go to documents and settings under your username. I can't remember the exact folder though.
Old 05-24-2010, 06:49 PM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
You might need to go into the Detailed Settings menu (in the SageTV UI) and enable debug logging. Then it should start generating the logs.
Aloha,
Mike
- Nikolaus (4yrs old)
Old 05-24-2010, 07:00 PM
Aloha,
Mike
That was it, thanks
Here is the log
Old 05-24-2010, 07:38 PM
That was it, thanks
Here is the log
Thanks for the log... found the problem... something is putting a commons-lang 2.2 in your JARs directory, and bmt requires 2.4.
JARs\commons-lang-2.2.jar
JARs\commons-lang-2.4.jar
I have no idea what plugin added commons-lang-2.2. You have alot of plugins installed, so it's hard to tell which plugin could have contributed it. Typically plugins are supposed to package their jar dependencies as separate plugins, but I'm not seeing any other plugin using commons lang.
You should be safe to remove the 2.2 jar and then restart.
Old 05-24-2010, 09:08 PM
Cool that fixed it, now i can't access the web GUI. I am guessing its because SABnzbd is also using port 8080. How can i change the port for the web GUI?
Old 05-25-2010, 05:41 AM
BMt uses the jetty webserver plugin. You should be able to change the port in the plugin configuration screen for jetty.
Metadata Tools 4.0 Beta Thread (aka BMT 4.0) stuckless Batch Metadata Tools 885 09-02-2013 08:03 AM
Metadata Tools Roadmap stuckless Batch Metadata Tools 0 05-21-2010 12:41 PM
Batch Metadata Tools new releases subscription thread stuckless Customization Announcements 18 02-17-2010 09:27 PM
Metadata Tools (Donations) stuckless SageTV Customizations 4 06-26-2009 05:54 AM
