Old 06-02-2010, 10:30 PM
goatboy22382 goatboy22382 is offline
No STV Component exists
When ever I try and install the server side components of a plug in I get the error
"STV Related Items need to be installed but no STV Component exists"
Any idea what is going on here? This is with a WHS server and a client on a core2duo machine.
Old 06-03-2010, 12:24 AM
GKusnick's Avatar
GKusnick GKusnick is offline
Maybe it would help if you said what plugin you're trying to install?
-- Greg
Old 06-03-2010, 08:59 AM
Specifically the comskip plug in and the stock manager plug in. I think that it is every plug in that has a server side and client side installation.
Old 06-03-2010, 11:00 AM
GKusnick's Avatar
Whenever you use SageTV Client to install a plugin, you're given a choice of whether to install it on the server or on the client. That does not mean the plugin has a server-side component; it just means there are two possible places you might have wanted to install it, and Sage is asking you which one.
If you're running a headless server, then there's no point installing STVI plugins on the server, because there's no UI there. That's probably what that message is trying to tell you (although I agree it's not worded very clearly). Just install the plugins on your client, and if they work, then you're done.
-- Greg
Test if MediaFile exists dflachbart SageTV Studio 9 05-23-2006 01:24 PM
A problem in Sage Beta 3.0.11 that previously didn't exists Ceger SageTV Beta Test Software 5 10-07-2005 11:20 AM
9800 + 350 Co-exists vikramtn Hardware Support 1 10-07-2004 10:08 AM
XMLTV grabber for Australia exists dir SageTV Australia/New Zealand 1 12-12-2003 01:10 AM
