Old 11-12-2010, 10:07 AM
eopian's Avatar
eopian eopian is offline
Sage7 and PowerDVD
In version 6 I have PowerDVD on my main menu so I can watch BluRay's with full menu support and what not. When I select PowerDVD SageTV minimizes until I close PowerDVD, then it rerturns when PowerDVD is closed. Is this easy to setup with version 7?
Server: i3-7100, 16GB Ram, AVerTVHD Duet(OTA), HDHR Prime, 2x2TB(recordings), 128GB m.2 SSD(os), 500GB SSD(data), 1x2TB (Movies), Win10Pro 64bit
Client 1: STP-HD300, Onkyo Tx-Sr707
Client 2-4: STX-HD100
Network: Linksys Router/Wifi, Netgear GS116 Switch, Cat5e/6, Intel NICs
Old 11-13-2010, 05:27 PM
sdsean's Avatar
sdsean sdsean is offline
Not sure, there is a plugin that lets you launch an external program with arguments for a video, but at the moment there is no way to easily customize menus, so this might be a bit of a trick.
I think you could also still use sagemc with version 7 and get that feature (I know you can use sagemc with 7, just not sure about customization of menus or program launching).
i7 3.33 GHz EE Quad Core+HT, 12GB DDR3 1333Mhz RAM, ATI HD6870 2GB VRM, 512GB Samsung SSD OS Drive, EVGA SLI x58 Mobo, Win7 Ultimatex64, Gyration MCE Remote, Hauppauge HD-DVR (x3), HD-HR, 2x H21-100, 1x H21-200 DirecTV STBs, 1 SIIG / CyberSerial 4 Port Serial PCI card, 1 PCIex1 Inland/NEC 5 port USB card
Old 11-13-2010, 08:08 PM
You can use SageMC in version 7 and customize the menu. I have done it successfully.
-Striker-
Old 11-13-2010, 08:11 PM
You can also check out the unofficial extras. I think there is some menu customization stuff in there.
http://forums.sagetv.com/forums/showthread.php?t=50000
-Striker-
Old 11-15-2010, 09:07 AM
Polypro Polypro is offline
I just have Windows 7 launch ArcSoft whenever it sees a BD, via the Auto Play settings.
P
Old 11-15-2010, 05:37 PM
eopian's Avatar
P
That's so simple that it should work. If it was just me, I would close sage and launch pdvd. My wife, however, likes it simple.
Thank you all.
Old 11-16-2010, 11:30 AM
If you program ArcSofts 'Exit' command into your remote, it's pretty seemless. Ctrl-X IIRC, but verify that.
P
Old 11-16-2010, 04:21 PM
eopian's Avatar
I already have my remote setup (with the assistance of usb-uirt and eventghost) to exit powerdvd and bring sage back up from sleep. I just use a simple comcast remote with usb-uirt, sage and eventghost. It works very well for my wife and me.
Old 11-16-2010, 08:37 PM
ranger ranger is offline
I use EventGhost as well, but had all kinds of problems getting it to work reliably with PowerDVD. I switched to ArcSoft because it worked better with my remote.
Going back to the OP query, with event ghost I programmed a button on my remote to minimize SageTV and launch ArcSoft. The button set up to exit ArcSoft also restores the SageTV window.
EXETuner Plugin with Sage7 Graygeek Hardware Support 13 05-08-2011 10:52 AM
Anyone trying Sage7 on Vail? rykr SageTV Beta Test Software 4 11-04-2010 05:29 PM
Fanart in Sage7 wayner SageTV v7 Customizations 4 08-05-2010 06:36 AM
Sage7 Feature Requests? texneus SageTV Beta Test Software 11 06-08-2010 04:57 AM
My wish for Sage7 or later... metapath SageTV Beta Test Software 9 06-03-2010 01:24 PM
