Old 11-14-2010, 07:08 PM
rgroves rgroves is offline
Sage7 for WHS
To upgrade a SageTV WHS to Sage 7, is a license key required to be purchased?
Old 11-14-2010, 07:48 PM
robogeek robogeek is offline
I think the short answer to your question is going to be yes. If you purchased your current SageTV version before Dec. 1st, 2009, you will need an upgrade license. If you purchased a version 6 license on or after Dec. 1st, 2009, then that key should also work with SageTV v7.
If you are running SageTV v6 and need to upgrade, then you will need to purchase a Windows version upgrade license. There is no specific WHS upgrade license, just get the SageTV Media Center for Windows Version 7 Upgrade item in the SageTV Store to get an upgrade key. The WHS version and non-WHS versions of SageTV use the same licensing system so the keys are interchangable between WHS and non-WHS Windows versions of SageTV.
--Jason
Server Hardware: GIGABYTE GA-EP45-UD3R, Intel Q9550 CPU 3.2GHz, 11GB RAM, 1xHDHR, 1xHVR1600, 1xHVR2250
29TB Server Storage: 1TB SSD (OS), 1TB (data), 2x6TB+2x10TB (22TB FlexRaid storage pool), 2x2TB (recordings), 1x750GB (VMs).
Server Software: Win10 Pro x64 OS, SageTV 64bit v9.2.0.441, Java 1.8 u201, PlayOn, Comskip (Donator) v0.82.003, WampServer v2.5.
Clients: 3xHD300s, 2xHD100, 2xPlaceshifters
Old 11-14-2010, 10:24 PM
Thanks, That's what I thought, but before I spent the $$$ on the license I figured I would check.... my luck, I would buy it, and find out I didn't...
Sage7 and PowerDVD eopian SageTV v7 Customizations 8 11-16-2010 08:37 PM
Anyone trying Sage7 on Vail? rykr SageTV Beta Test Software 4 11-04-2010 05:29 PM
Fanart in Sage7 wayner SageTV v7 Customizations 4 08-05-2010 06:36 AM
My wish for Sage7 or later... metapath SageTV Beta Test Software 9 06-03-2010 01:24 PM
HDhomerun and whs version of sage7 goatboy22382 SageTV Beta Test Software 4 05-31-2010 02:13 AM
