Old 05-19-2011, 10:25 AM
DFranch's Avatar
DFranch DFranch is offline
Sage version 6.6.2 on Windows 7 64 bit
Does anybody know if Sage TV Version 6.6.2 will work with windows 7 64 bit, or will I have to get the upgrade to Sage TV 7? Specifically I have 2 Hauppauge HVR 2250 cards and 1 PVR-150.
SERVER: Gigabyte EP45-UD3R | Intel Core 2 Duo 2.67 Ghz | Geforce 8500GT | 4 Gb Corsair DDR2 1066 |
2 Hauppauge HVR-2250 | Win 7 64-bit | Sage TV 6.6.2 | 1.6TB (4 Drives) |
Client: Sage TV STX-HD100 HD Extender
Old 05-21-2011, 10:28 AM
Tiki's Avatar
Tiki Tiki is offline
Yes it works.
However, The PVR-150 will not work (it will cause crashes) if you install 4GB or more memory (you must have less than 4GB installed) on a 64-Bit OS. 2 or 3GB of RAM is OK.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 05-21-2011, 02:17 PM
DFranch's Avatar
Hey, thanks for the reply. Yea, I read that about the PVR-150. It's too bad, as I intend to use 4 GB or ram. I'll either make due with 4 tuners, or I'll get another tuner down the road (before fall season).
Building semi-dedicated PC Sage client: Which windows version? mmanville General Discussion 14 09-10-2010 02:38 AM
Which version of Windows 7? Merc1032 General Discussion 17 03-14-2010 12:15 AM
Which Java version for 64 bit Windows? farfromuman SageTV Software 1 02-04-2009 04:35 PM
SageTV Media Center for Windows Version 6 Upgrade zazz SageTV Software 1 05-28-2008 08:09 PM
Do Customizations work with the Windows Home Server version? Grant SageTV Customizations 1 01-02-2008 07:05 PM
