Old 02-09-2012, 06:16 PM
KryptoNyte's Avatar
SageTV + Comskip 81.028 working?
Can anyone verify if the latest donator version of comskip, v81.028, is working properly with SageTV recordings? I've been playing with it and it seems like Comskip is finding commercials okay, but the commercial cutting timeline appears shifted with respect to the show itself.
I've made the .ini tweaks relative to SageTV for some bug that apparently exists in Sage recordings that I wasn't aware of, so I don't think that could be it.
Any other ideas or tweaks? It sounds like there has been some serious improvements in Comskip over the last few months, so I was really hoping to get it working.
Thanks.
Old 02-09-2012, 07:01 PM
My guess is you are using a capture device that has a along initialization time, so the 'timeline' numbers in sage are being scaled to make it 'appear' to be a full hour (or half, whatever). This will throw off comskip playback. There is an option in the comskip playback options that will disable this scaling (Setup -> Detailed Setup -> Control Options -> Timeline Scaling). This should clean up the cut points.
Old 02-10-2012, 08:16 AM
rochurch rochurch is offline
Can you point me in the right direction to find those " .ini tweaks relative to SageTV" (yes, I did a search here) I use a combination of SA and Comskip. Comskip does a better job, but it is much slower on .ts files. I am a donator so I might try and move up to the latest version and give it a try on all channels.
Old 02-10-2012, 09:09 AM
I've always just used the comskip.ini file that comes with the CommercialDetector plugin. It's got the changes in it. It's just things like the output settings, and the logging levels i believe.
Old 02-10-2012, 10:03 AM
Ahh, great. I'll go grab that and copy it in then. Thanks Fuzzy, you are a Sage of SageTV.
Old 02-10-2012, 12:43 PM
KryptoNyte's Avatar
If you grab the latest version of comskip, it is apparently working much faster on the h264 files. If you do get that latest version, please post back if you would on whether or not it's working properly with SageTV recordings specifically.
Old 02-10-2012, 02:11 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Yes, let us know. If it's good I'll update Commercial Detector to use it.
Old 02-10-2012, 03:13 PM
Easy enough because I have a few channels that SA gets stuck on, so I have those coded to use comskip and default is SA. I'll update comskip and tell commercial detector to not use SA as default. I'll report back my findings.
Old 02-12-2012, 08:09 PM
farfromuman farfromuman is offline
The latest version of comskip has this in the readme:
WARNING!!!!!!!!!!!!!!!!!
the current comskip version can not process files while recording. If used that way comskip will end premature and not find commercials.
Make sure comskip is started when the recording is completely finished. For .wtv recordings wait 10 minutes after last writing of the recording.
It did work properly until I disabled live tv detection.
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT
Client 1: HD300; Panasonic TC-P65S64;
Client 2: HD300; Samsung 46" LCD;
Client 3: HD300; 60" LCD;
Old 02-13-2012, 05:25 AM
Wow, sombody read the readme file. I didn't and got pretty bad results. I ended up going back to ShowAnalyzer for the majority of my channels. It now sounds like I need to make sure that I swap out Comskip to the version I was using since it was capable of scanning currently recording shows.
I don't watch a lot of TV, but my watching pattern has me watching a lot of shows shortly after they have started recording. I am an old ReplayTV user and habits are hard to break.
Has anybody got Comskip working in the UK emotionnotion SageTV United Kingdom 2 01-20-2012 02:26 AM
ComSkip not working.. koan00 SageMC Custom Interface 6 11-10-2009 06:47 PM
Can't get comskip working 73cuda SageTV Customizations 23 03-18-2008 09:45 PM
SA/COMSKIP on HD files not working... twieder SageTV Customizations 10 02-21-2007 10:51 PM
Comskip not working BBCritical SageTV Customizations 2 07-25-2006 07:11 AM
