Old 10-03-2014, 10:06 AM
michaeldjcox michaeldjcox is offline
Iplayer anyone?
I've written a sagetv plugin to hook iplayer into online videos.
I know the sage TV + UK audience must be about three of us by now.
I know theres a million ways to get iplayer but my family all like the one-stop-shop sageTV solution and I don't want to pay for any more hardware to get iplayer on the big screen - internet enabled TVs etc.
There probably are solutions around uPNP also but I found all that such a pain to use - a dodgy middleman.
It may well all go to pot if BBC encrypt.
And I don't really have the energy to provide the kind of support I offered for webfeedencoder but if theres any takers I'll post it up.
It does watch now and record (and place in TV recordings with decent meta-data).
I have plans to link to watched, and favorites and EPG i.e. so you can click on past EPG programmes and get them recorded. I would also like to add a STVi import at some point to replace the podcast based watch/record/stoprecord controls. And of course I would like to extend into 4Od, 5OnDemand, ITVPlayer etc
Michael
Web Feed Encoder developer
SageTV Catchup developer
Old 10-04-2014, 12:46 AM
deanm deanm is offline
I must be one of the 3 then.
Great work. I would be very intrested in helping in testing this.
Been hoping this would be implemented by someone.
Like you I just want everything in one place with one remote.
Dean
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 10-04-2014, 08:36 AM
PeterC PeterC is offline
This sounds like it will be useful, will it work on an XP server ok?
Peter
Old 10-04-2014, 09:22 AM
pjwerdna pjwerdna is offline
Smile
Iplayer integration would be great.
Ive been using get_iplayer to download things SageTV misses recording. That works but its a bit of a pain do to.
Also hope it works on XP, but if it doesnt I guess it would be the push I need to upgrade windows.
SageTV Server : Akasa Inifiiti Case, Gigabyte GA-P35C-DS3 MB, 8600GT, Core2 Duo (E6850 3GHz), 4GB RAM, ~6TB Filestore , Nova-TD500, TBS 6280, SageTV 7.1.9
New Client 2 :MSI P67A-GD53, i5 2500K Quad core (3.3GHz), 12GB, Windows 10 Pro (and test SageTV 9 Install)
Sage Client 1 : HD300, Logitech Harmony One
Old 10-04-2014, 06:25 PM
tvmaster2's Avatar
BBC iPlayer? That would be great! Could us foreigners hook in directly via Sage, or would we still need VPN connections?
Old 10-05-2014, 04:07 AM
rickgillyon's Avatar
Sounds interesting to me, save me getting missed stuff on get_iplayer...
unRAID Server: Intel Core i5 7600K, 16GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x4TB SATA3 Parity Drive, 2x3TB + 1x4TB SATA Array, 1x TBS 6284 PCIe DVB-T2 Quad, 2x TBS 6205 PCIe DVB-T Quad, Cable TV from TBS2603 sat/IP, IPTV via Telly & node-ffmpeg-mpegts-proxy, unRAID 6.6.6, TVheadend for recording back end, OpenDCT, SDEPG, SageTV 9
Clients: 3 Nvidia Shields, 2 Android Miniclients (Amlogic S905X), 3 Win10 Pro PC Clients
Old 10-06-2014, 01:03 AM
pukka pukka is offline
can I be sage user number 4 please
Old 10-06-2014, 03:41 AM
No comment on the iplayer for outside the UK!
Not helping on that one - don't want the Beeb to go on a nailing it down crusade.
The plugin makes calls to get_iplayer which needs to be installed separately.
The plugins chief job is to collect meta-data, interface with get_iplayer, and present podcast XML to sagetv online services.
Its written in such that iplayer is one of a number of plugins that provide a metadata and play/stop interface which is presented in a common format to SageTV. The plugins are scripted in groovy to give a "softer" edge to the plugin so local mods can be made to get things working without need for release.
Its tested with Windows 7 and LinuxMint/Ubuntu linux.
It will probably work with XP - though I know from webfeedencoder development that windows can be a real pain when it comes to permissions and launching cmd shells. Should all be resolvable though.
I have a version running on windows 7 at home being rigorously QA'd by my 7 year old.
There is a bug I'm working to fix first so I estimate a few days before I try and release.
Regards,
Michael
Old 10-06-2014, 08:52 AM
Bagal Bagal is offline
I'd be interested in trying this out as well!
Server: Win7 64bit; i5 2500; 32GB ram; Blackgold BGT3595; 18TB + 120GB SSD; Edgestore DAS401T; DVBLink; Oscam; Omnikey 3121
Lounge Client: HD300; Yamaha RX-V765 connected to 55" Furrion 1080p LCD; Logitech Harmony One remote
Kitchen: HD300 32" LCD, Bed 1: HD300 - 40" LCD, Bed 2: HD300 - 24" LCD, Bed 3: HD300 - 22" LCD
Old 10-06-2014, 02:40 PM
mevans mevans is offline
I'd like to give it a go too - although i'm currently transfering STV from a WHS(v1) system to Win8.1, so I'll let that settle down before i go trying your iPlayer plugin.
You see - there are more than three of us left!
Keep up the good work!
mevans
Server: ASUS P7P55D, Core i5 750 2.66GHz, 4GB RAM, Antec Three Hundred, 1x TBS 6284 PCI-E DVB-T2 Quad (OTA HD 'Freeview'), 2x HD Homerun dual tuners (OTA SD 'Freeview'), WHS OS installed on Seagate 250GB SATAII, Recording to 9TB Storage Pool (64k clusters)
SageTV version: 7.1.9
HDHomerun's plugged into mobo NIC via giga switch
2nd NIC to home network
Program Guide: DigiGuide Birtles Grabber XMLTV Importer for SageTV
Clients: Two HD200, One HD300, Client on PC, Placeshifter on PC
Old 10-07-2014, 01:25 AM
Which probably shows you the dearth of alternatives out there...
Old 10-07-2014, 10:20 AM
doc doc is offline
I'm still here too......
I'd definitely be interested. Have a roku and a youview box but spend most of my time in the back bedroom/hobby room and the TV only has 1 HDMI which just happens to have the HD300 plugged into it.
Old 10-07-2014, 02:10 PM
taylormadearmy taylormadearmy is offline
yes please
Old 10-09-2014, 02:18 AM
jamesdisco's Avatar
jamesdisco jamesdisco is offline
This sounds great i'll help you test.
Server: Win 10 64bit Core i3 8GB 20TB, TBS6985, TBS6984, Sage 9.
Clients: 5 x HD300, 2 x HD200, Placeshifter.
Old 10-09-2014, 02:57 AM
Plan to release a version Friday/Saturday - just doing a little bit of "productisation" before I let it out the door
Old 10-15-2014, 12:01 PM
Submitted the plugin today.
Will get around to some announcements notes tomorrow.
Old 02-17-2015, 11:45 AM
SidKnee SidKnee is offline
Sounds like UK use of SageTV isn't quite as dead as I thought I'll definitely give this a go!
BBC Iplayer goes open source Oddity SageTV United Kingdom 0 03-30-2013 02:30 AM
Developer Challenge: BBC iplayer integration jamesdisco SageTV Customizations 18 12-15-2010 06:01 PM
IPLAYER willplaice SageTV United Kingdom 1 04-15-2010 10:28 AM
BBC iPlayer taylormadearmy SageTV United Kingdom 8 07-27-2009 01:43 AM
BBC iPlayer Plugin? moamoa SageTV Customizations 3 11-04-2008 01:06 PM
