Old 05-11-2015, 09:11 AM
Damstas Damstas is offline
2.43 Web Interface issues
I have installed version 2.43 of the web interface, but am encountering issues when trying to open it up.
I have typed localhost:8080/apps/ and try to type sage as the username and frey as the password. It just won't let me in. I don't know what's causing this.
Old 05-13-2015, 12:30 AM
Anyone?
Old 05-13-2015, 09:48 AM
robogeek robogeek is offline
The username and password is stored in SageTV\SageTV\jetty\etc\realm.properties. In that file, is this line there and uncommented?:
sage: frey,user
--Jason
Server Hardware: GIGABYTE GA-EP45-UD3R, Intel Q9550 CPU 2.83GHz, 11GB RAM, 1xHDHR, 1xHVR1600, 1xHVR2250
29TB Server Storage: 1TB SSD (OS), 1TB (data), 2x6TB+2x10TB (22TB FlexRaid storage pool), 2x2TB (recordings), 1x750GB (VMs).
Server Software: Win10 Pro x64 OS, SageTV 64bit v9.2.0.441, Java 1.8 u241, PlayOn, Comskip (Donator) v0.82.003, WampServer v2.5.
Clients: 3xHD300s, 2xHD100, 2xPlaceshifters
Old 05-13-2015, 06:34 PM
Denali Denali is offline
What version of JAVA? Broken with JAVA 8, must use 7 or 6.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 05-14-2015, 07:14 AM
I downgraded to version 7 of Java.
My realm.properties shows this:
#user: password
sage: sage,frey
Can't get in with those..
Old 05-14-2015, 07:59 AM
The line:
sage: sage,frey
should be:
sage: frey,user
or just:
sage: frey
Try changing that and see if it works.
--Jason
Old 05-14-2015, 11:51 AM
Originally Posted by robogeek View Post
The line:
sage: sage,frey
should be:
sage: frey,user
or just:
sage: frey
Tried the frey, user
Not working.
I also tried the frey, and it gives me this error:
Problem accessing /apps/. Reason:
User not in required role
Old 05-14-2015, 01:32 PM
Mark57's Avatar
Mark57 Mark57 is offline
Robogeek is correct.
You'll need to restart Sage or restart Jetty in the plugin manager for your realm.properties file changes to take effect. If Sage is running as a service, stop the service before editing.
Everything in my realm.properties file is commented out (# character in front of the line) in the whole file except for
#user: password
sage: frey,user
Mark
____________________
Server: Scratch built server, 16GB RAM, Nvida GeForce 8600 GTS, 6 HD Homeruns, 32 TB Storage, Windoz 10 64 bit, Sage 64 bit 9.2.1, Sage HD-100 & 200 Extenders
Old 05-14-2015, 02:14 PM
#user: password
sage: frey,user
I changed to those, but I got in with username: sage password: frey. Really weird.
Though all I get is this:
HTTP ERROR 500
PWC6033: Unable to compile class for JSP
PWC6199: Generated servlet error:
The type java.util.Comparator cannot be resolved. It is indirectly referenced from required .class files
Caused by:
org.apache.jasper.JasperException: PWC6033: Unable to compile class for JSP
at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:123)
at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:296)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:376)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:437)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:608)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:360)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:486)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:380)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:389)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:334)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
at org.mortbay.jetty.servlet.DefaultServlet.doGet(DefaultServlet.java:493)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1157)
at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:131)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1148)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:387)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.handler.rewrite.RewriteHandler.handle(RewriteHandler.java:230)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:864)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:539)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:520)
Powered by Jetty://
Old 05-14-2015, 02:26 PM
you need to verify that you are NOT running Java 8. This error looks like the error I got when I tried to move to Java 8.
Old 05-14-2015, 06:05 PM
Did you shut down Sage and service then uninstall JAVA before downgrade? NEVER EVER change JAVA without shutting down Sage first.
Old 05-15-2015, 12:49 PM
Now that you mention it I am not sure. What should I do to proceed? I uninstalled Java 8 and downloaded Java 7.
Old 05-15-2015, 05:46 PM
If your not sure, I would shut down SAGE, uninstall JAVA, reboot, install JAVA 7, start SAGE.
Old 05-17-2015, 07:23 AM
Did that. I'm still seeing that error.
Old 05-17-2015, 09:49 AM
If you are still seeing the exact same error then it would seem to indicate that SageTV is still using Java 8 (32-bit version), since that jetty-related error you posted has been linked to a failure caused by running the SageTV version of the Jetty Server with Java 8 (32-bit version). If you had both the Java 8 JRE and Java 8 JDK installed, did you uninstall them both? When you reinstalled Java 7, did you reinstall the 32-bit version of Java (SageTV requires the 32-bit version of Java)?
If you still can't get it figured out, do you have the SageTV debug logging enabled? If not, enable it (Setup>Detailed Setup>Advanced>Debug Logging). Once enabled, restart SageTV, wait until it is fully started, and then find the sagetv_0.txt file in the SageTV folder (probably in C:\Program Files (x86)\SageTV\SageTV). In the very first few lines of that log file you can see what version of Java your SageTV is using, and a little further down in the log file you might be able to see what (if any) plugins are crashing, complaining, or failing to load during startup. If you need help interpreting the log file, zip it up in an archive, and post it here.
--Jason
Interface issues still exist with latest Mac beta oopsydaisy SageTV Beta Test Software 2 10-15-2009 01:47 PM
Interface changes in 6.5.11 baudfather SageTV Beta Test Software 1 03-11-2009 04:45 AM
HD200 - cool, but 2 issues - memory & playback issues with hdpvr agover SageTV Media Extender 3 12-16-2008 12:50 PM
Media Center 6.3 Interface Issues KKnox SageTV Software 6 12-20-2007 12:55 PM
Couple Issues (sound and interface) Tengen SageTV Software 5 01-23-2005 01:44 PM
