Old 07-23-2015, 11:29 AM
Pelicanjoe Pelicanjoe is offline
Windows 10 rolls out July 29th
So, Windows 10 is rolling out on July 29th.
  1. Are you going to upgrade your sage tv server?
  2. You have 1 year to upgrade. Is anyone going to take advantage of this upgrade?
  3. How do you feel about the forced updates required for the home edition?
Old 07-23-2015, 12:19 PM
1. NO
2. YES
3. Do not care.
Old 07-23-2015, 01:02 PM
Taddeusz Taddeusz is offline
I will probably upgrade my SageTV server. If not right away then at least within a couple months. It's currently running 8.1.
I personally won't be affected by the mandatory upgrades as all my Windows 8 licenses are for Professional, not Home. However, I believe it's a good thing that Home versions have mandatory updates. I know from experience that optional updates have made home users in particular lazy about installing them. I have personally seen XP systems go unpatched for years and end up infected with who knows what. Updates are already effectively mandatory anyway unless you have the technical ability to disable it (or own a Samsung system). I really don't see making updates fully mandatory for the Home version that big of a deal. All it really means is that for techies who really care and want to avoid it Microsoft will make more money from them buying Professional. As long as there isn't a way for malware to disrupt updates as is currently possible it should lead to more secure home computers.
Old 07-23-2015, 01:57 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
1. Yes, but not to W10. Eventually going to go from XP to W7.
2. For any W8 computers, yes.
3. Like Taddeusz, most of my PCs are on Pro.
I do wonder about something. Can you manually uninstall an update? If so, will MS just keep reinstalling it? I ask because I wonder what happens if an update breaks your system and, to remedy the situation, you do a system restore or a full restore from a backup.
Software: SageTV 7
Old 07-23-2015, 03:29 PM
Fluffdaddy Fluffdaddy is offline
I'm sticking with 7 on my sagetv server. It just works.
On my gaming pc and laptops windows 10 all the way.
I like free
We’re doomed. It will never work
Old 07-24-2015, 02:56 AM
I do wonder about something. Can you manually uninstall an update? .
You usually can't uninstall an operating system (without dire consequences). I guess if you back up everything before upgrading, you can restore.
Old 07-24-2015, 04:28 AM
I think he was talking about individual Windows patches. Just in case one caused major issues.
Old 07-24-2015, 07:40 AM
pjpjpjpj pjpjpjpj is offline
Having not looked into win10 at all, does this mean updates and patches will automatically download and install when pushed? Or will you be asked? And what makes it "mandatory" ... Will the machine just stop until you install the update?
I ask because if either of these situations are true, and updates (as usual) force reboots, this could occur in the middle of Sage recordings (or watching something on an extender)...
How will this work?
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Software: SageTV v9, stock STV with ADM.
Old 07-24-2015, 09:39 AM
andre5006 andre5006 is offline
1. No, HTPC on 7.1 will - wait for someday when nothing else to do
2. No, Have MSDN so whenever
3. Good, best way to keep "I just want to use it" people safer
Will upgrade main client machines as-soon-as-RTM.
Old 07-24-2015, 10:48 AM
Yes, you usually can uninstall an update - I have done it in the past when updates have broken something which happens, albeit not that frequently.
On Win7 I believe you do this via Control Panel/Programs and Features/Installed Updates.
Old 07-24-2015, 10:49 AM
Skirge01's Avatar
Correct.
The quick answers for users of the HOME version are YES, NO, NO. Everything will be mandatory, though... both updates and changes (additions or removals) to features.
How will this work?
This is the most thorough article I read on the subject, but it doesn't answer the--very valid--question about reboots. I suspect the reboots will not be forced and most likely we'll have similar options to W8, in that you'll be able to postpone the reboot, but not forever.
Software: SageTV 7
Old 07-25-2015, 05:07 PM
jgsouthard jgsouthard is offline
  1. MAYBE. I'm on Windows 7 now and it's working OK, but I really like Windows 8.1 on my other computer and from everything I've read Windows 10 may be the best Microsoft OS since Windows 7. But I'd really like to hear from other SageTV users who are running Windows 10 to make sure that it works OK.
  2. Definitely, on every one of several computers that I support that are running Windows 7 or Windows 8.1. OTHER than maybe SageTV -- I want to make sure it works and no one is currently around to test and revise SageTV to make sure that Windows 10 is supported.
  3. I didn't know about forced updates. I think it's a good idea for all Microsoft OS updates, but I don't want them to force updates to hardware drivers. I've had way too many problems over the years with Microsoft drivers vs. ones I've gotten directly from the manufacturer. In MOST cases I think using the Microsoft drivers and accepting updates is the best approach, but in a few cases where I've had to move to a manufacturer's driver to get things to work, I don't want a Microsoft update to overwrite the manufacturer's driver and screw things up (and that WILL happen, if the updates are mandatory).
Old 07-26-2015, 03:40 AM
maceie maceie is offline
Mandatory updates
Originally Posted by jgsouthard View Post
  1. ...I don't want a Microsoft update to overwrite the manufacturer's driver and screw things up (and that WILL happen, if the updates are mandatory).
Oddly, right now I am waiting for someone to arrive at my house with their hardware so I can remove the Windows update driver for the NIC and let it use the previous one.
So this is a very real possibility.
(talking them though it just wasn't an option. Sadly)
Old 07-27-2015, 07:52 PM
Skirge01's Avatar
No clue if this tool will be permanently available for the final release, but it's a good sign. It also answers the question of whether drivers are being forced upon us: They are.
Software: SageTV 7
Old 07-28-2015, 09:27 AM
If you want no part of the update see this site. I do not want to upgrade my server so I removed the update.
http://winsupersite.com/windows-10/h...ng-your-system
Old 07-28-2015, 10:06 AM
Skirge01's Avatar
That has only been bugging me on my W8 system because it keeps popping up windows reminding me about it, rather than like on my W7 systems, which the icon just sits by the clock. Those notices from W8 which take over your desktop with a faux full screen message are probably the second most annoying "feature" of W8. "Oh, sorry, were you looking at some other window? We think you'd like this one much better!" Anyone know if W10 got rid of that crap?
Software: SageTV 7
Old 07-29-2015, 08:32 AM
In the reviews and stories I've seen, I have not seen an answer to this question:
Can you download the upgrade software (since it's free) and not install it? Then someday down the road (say, in 5 years, if Win10 is as popular as they expect and we've confirmed it's completely safe with Sage) install it, and have it still be free?
I'm guessing not, because I suspect the download/install will likely be an integrated process and you won't just download the entire OS in a lump file... meaning you'll just be downloading the installer first, and then other pieces will download as the installation progresses... and I doubt the "free-ness" will be inherent in the original installer stuff you'd download today and therefore give you a free pass five years from now...
Old 07-29-2015, 10:25 AM
Skirge01's Avatar
From what I've read, the license key for the existing OS is invalidated in order to activate W10, thereby replacing the old key with the new one. So, all MS needs to do is stop doing that when the offer ends and W10 won't activate.
Software: SageTV 7
Old 07-29-2015, 10:28 AM
Really? That would imply you can't "roll back" to the old version. If that's the case I'm not upgrading, at least not for a while.
Or maybe I'm missing something?
Old 07-29-2015, 10:40 AM
By Roll back are you including restoring an Image? I have Imaged my system that I can plan to upgrade ... I am sure that if I restore that image I can re-activate 8.1. Maybe there is no roll back if you Install the upgrade and cannot uninstall it but I doubt the license itself will be null and void for a clean re-install of 8.
It simply states that you cannot use the windows 7 or 8 KEY in another PC which is the way it always works.... If you upgrade to windows 10 you cannot just go and use that windows 7 or 8 key in another PC.... that is fair enough.
More Here...
http://answers.microsoft.com/en-us/i...2207344?auth=1
Download Tool.
http://www.microsoft.com/en-us/softw...load/windows10
Plex Hacked July 1, 2015 tvmaster2 General Discussion 5 07-08-2015 02:43 AM
Anyone using HD-PVR 1.5.7.0 July 1, 2010 drivers? davephan Hardware Support 9 09-20-2010 08:56 AM
Need to have a 4th of July coupon ... Old_Skool General Discussion 3 06-28-2009 09:06 PM
is a july purchase v4 or v5? avonnied SageTV Software 1 01-02-2007 08:23 PM
STV: MlbDude2 1.8.7 - July 5 mlbdude SageTV Customizations 583 11-08-2004 04:18 PM
