Old 09-15-2015, 11:41 AM
Damstas Damstas is offline
Schedules Direct plugin not compatible
What I did
1) I downloaded SageTV for Windows 7.1.9.
2) I installed it and replaced the SageTV.exe file with the one that wnjj had made.
3) It launches and plays ok, but neither of the Schedules Direct plugins seem to work (0.0.8.1 and 1.0.0.1). Both have "not compatible"
Incompatibility Reason: Java Version 1.7+
What should I do?
Old 09-15-2015, 12:13 PM
Originally Posted by Damstas View Post
What I did
What should I do?
You need to install Java 7 or higher on your box.
Old 09-15-2015, 12:14 PM
But I have. :/
These are installed:
Java SE Development Kit 8 Update 51 (64 bit)
Java 2 Runtime Environment, Se v1.4.2_19
Java 8 Update 60 (64-bit)
Java(TM) 6 Update 10
Old 09-15-2015, 12:18 PM
But I have. :/
I saw some posts in the past that there were problems with version 8 but I thought that was with SageTV 7.1.9 and earlier.
Try dropping to Java 7 then and see if that fixes your problems.
Old 09-15-2015, 12:25 PM
Where can I download it? It says on Oracles website that they don't offer it anymore.
Old 09-15-2015, 12:26 PM
To be clear, SageTV core has no issues (that I know of) with Java8, but the Jetty web server does have issues, and because of that other plugins that might leverage it, also has issues (incuding bmt and sagex remote apis).
So, Java 7 for the server, for now, until the plugins are updated to be Java 8 compatible.
Old 09-15-2015, 12:33 PM
I found Java 7 Update 80 and installed it. I now have version 7 along with version 6, which was a required install with the server. Still says "Not compatible"
Old 09-15-2015, 01:05 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Look in the Windows registry under HKLM\Software\JavaSoft\Java Runtime Environment\CurrentVersion
Be sure it's not set to 1.4 and is set to the Java 7 one instead (it should match one of the keys below this folder...so likely 1.7).
Jeffrey Kardatzke
Google
Founder of SageTV
Old 09-15-2015, 01:50 PM
It was set to 1.6. I changed it to 1.7 and now when I'm trying to start Sage it says: "Could not get information on current JVM." It works only with 1.6.
Also I installed the DVBDecrypter plugin and now the server crashes and restarts infinite times without any error messages.
Old 09-16-2015, 03:58 AM
But I have. :/
SageTV is a 32-bit Java program, so those two 64-bit are not used. It was likely running with the 6u10 version that was installed.
Old 09-16-2015, 07:08 AM
Ok, thanks. That's probably it. I can't try it because of this infinite reload situation.
EDIT: Got it installed now and fixed the reload issue.
Old 09-16-2015, 11:32 AM
Got everything set up now (thx everyone for helping out), but I am wondering one thing. How can I see the episode artwork that comes from Schedules Direct, like in this pic: http://static.flickr.com/4035/4621050583_4d81417253.jpg
Where the picture is supposed be, I have currently ongoing TV-show.
Old 09-16-2015, 01:32 PM
Slugger Slugger is offline
The sagetv plugin for SD does not currently support fanart. For fanart, you'd have to add a plugin that deals with fanart (BMT, I believe) and you'd have to use an STV (or STVi) that knows how to use that fanart source and display it.
The raw SD data that my plugin pulls down has all the references to all the fanart you'd ever want, just the plugin doesn't support accessing it, loading it into wiz.bin or otherwise displaying it. I decided to defer those features to other already available plugins.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 09-16-2015, 01:39 PM
The SD is the only source that has good artwork data in my country. Lot's of shows will then miss artwork.. Any chance of adding this feature?
Old 09-16-2015, 04:09 PM
Or maybe (the means of provisioning for) a plugin for the SD plugin?
Sounds like the SD service is a good source for a number of things, and while other plugins may be going to other sources to obtain/handle those items. Should they want to make use of SD as well, why not do (hopefully) a little work to allow them to potentially use the SD plugin as a means of getting to it?
Old 09-16-2015, 05:34 PM
I don't want to provide false hope, so I'll just give it to you straight...
I personally have no plans to do it. I use Phoenix2 and its fanart mechanisms (BMT, etc.) to grab and display all the fanart I use. It works for me and so adding the extra features to the SD plugin just isn't on my radar.
The SD plugin arose mostly out of fear when Google moved in. My only goal with that plugin was to load my wiz.bin with epg data in case the worst happened. It does that and so I don't really plan on doing much more with it other than maintaining the current functionality.
But the good news is all the source code (for both the Sage plugin and all the SD apis it uses) is on github. I gladly accept pull requests from anyone wishing to enhance the current plugin. If someone wants to completely take over the Sage plugin and run with it, I'm open to that, too. As I said, the most I expect to do with the plugin is to maintain currently functionality if/when SD updates their protocol, which I'm hoping doesn't happen anytime soon. I have a few wishlist items for the plugin, but no plans to even look into those before 2016 and none of those items from my list have to do with fanart support.
Twitter: @ddb_db
Old 09-16-2015, 06:02 PM
Support for people & show art is something I plan to do for SD... but that comes with a caveat that it might not be real soon either.
Andy
Old 09-17-2015, 01:42 AM
Ok, thanks for letting us know.
Andy
Great to hear! To you have any ETA to give. Weeks, months?
Old 09-17-2015, 06:33 AM
Completely understandable, you made it to do something you needed it to do. You decided to share it with others because you wanted to. You don't need or want it to do those other things, and you don't benefit from making them. Thank you for doing what you have done.
For which other plugin authors can be thankful for, should they decide to use SD as a media source in the nearish-future, as it saves them from having to reinvent the wheel to access SD with Sage.
Old 09-18-2015, 07:26 AM
Yes, that probably covers the anticipated time frame. Sorry, but I can't give an estimate. (And if someone else beats me to it, that's fine too.) In my previous post, I just wanted to say that getting some of that extra info out of the SD EPG data source was going to be done at some point.
Andy
Plugin: Schedules Direct EPG (not for v9) Slugger SageTV v7 Customizations 851 07-19-2017 07:48 AM
Plugin: Schedules Direct EPG Source for SageTV OSS Slugger SageTV v9 Customizations 89 10-11-2016 07:31 AM
Schedules Direct EPG Plugin: Call for private beta testers Slugger SageTV v7 Customizations 11 01-19-2013 11:59 AM
Schedules Direct EPG Plugin PoC Completed Slugger SageTV EPG Service 71 12-04-2011 12:12 PM
