Old 02-07-2016, 11:14 AM
Class Action Lawsuit against Seagate
I had several 2 TB fail on me rather quickly also the replacements were just as bad.
http://www.tomshardware.com/news/sea...3tb,31118.html
Old 02-07-2016, 02:15 PM
EnterNoEscape's Avatar
I keep a spreadsheet of the hard drives I use. Most of the 3TB Seagate hard drives I purchased a year ago failed in less than a year and all 3 of my warranty replacements failed in less than 3 months. I stopped bothering because it wasn't worth the cost of shipping it back to them for another 3 month refurb. I now only buy Toshiba (WD is good, but they are more expensive). I have had only one Toshiba failure and many of the ones I have today were purchased at the same time as the first Seagate hard drives.
Old 02-07-2016, 04:51 PM
Dargason Dargason is offline
I'm glad I just replaced my 3TB seagate (which was failing) with an HGST.
Old 02-12-2016, 08:05 PM
farfromuman farfromuman is offline
I had 4 out of 4 Seagates fail, the last 3TB was out of warranty. Never had a drive fail before this, probably because they were other brands.
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT
Client 1: HD300; Panasonic TC-P65S64;
Client 2: HD300; Samsung 46" LCD;
Client 3: HD300; 60" LCD;
Old 02-14-2016, 11:46 AM
hemicuda's Avatar
hemicuda hemicuda is offline
Wow. Almost all my drives are SG, even in the RAID box. I still have one 3TB sitting in the shipping box planned for security recordings.
We had 2 fail in an 8bay raid box at work a couple years ago. Lucky we got the array rebuilt before the 2nd failed the next week.
Server: MS Win7 SP1; FX8350 (H2O cooled); 8GB RAM; Hauppauge HVR-2250 (OTA); HVR-1800 (OTA); SageTV 9.1.5.x; 12+TB Sage Storage
Clients: HD300 x2; HD200 x2; Placeshifter
Service: EPB Fiber (1Gb); OTA (we "cut the cord"); Netflix, Hulu, etc.
Old 02-14-2016, 05:19 PM
pjpjpjpj pjpjpjpj is offline
I've stayed away from Seagates on the advice here (and this thread makes me glad).
However, in December 2005 (I know because I just ran across the box and receipt last week!), I bought a 40GB Seagate portable drive that has remained plugged into my work computer (holds my personal files, music, etc.) and it's been running just fine for 10.5 years now. So either I got lucky, or they were putting out a better product a decade ago.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Software: SageTV v9, stock STV with ADM.
Old 02-14-2016, 06:12 PM
KryptoNyte's Avatar
I've had good success with Seagate drives - after a handful of them in the past 5 or 7 years, I have never had a Seagate failure. I have had 100% failure on (3) Western Digital Green drives, however - the (3) drives that WD sent as a replacement under warranty are working (with the head parking disabled).
Old 02-14-2016, 07:00 PM
Tiki's Avatar
Tiki Tiki is offline
I think it was just the 3TB Seagate drives that were a problem. I had 3 of them and all failed after about 2 years. They were the 3TB Barracuda models.
Other sizes and models of Seagate drives I think had similar reliability to drives from any other manufacturer.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 02-14-2016, 07:42 PM
JustFred JustFred is offline
Sadly, the failures go well beyond the 3 TB drives. I've gone thru over a dozen 1.5T and 2T Seagate desktop drives. Even though they'd been installed in a range of different enclosures and systems, they all failed at about the same age. During one 4-month period, I had more than 6 drives rotating thru the warranty replacement process. And then the replacements themselves all failed at about the same time. Amazing how each of them would all suddenly develop large numbers of bad sectors (20, 30, 40, as reported by SMART monitoring software). Nearly 100% failure rate at 5 yrs. Total junk. It'll be a long time before I buy another high-capacity Seagate disk.
On the other hand, most of the smaller-capacity Seagate disks (160GB and smaller) are still running well with more than 10 years on them. Still no grown defects. Obviously a completely different design.
Old 02-15-2016, 11:50 AM
The biggest problem I've had with drives is the shipping. If you buy retail drives the problems are drastically reduced. I try to never buy OEM drives any more and definitely DON'T buy OEM drives from Newegg.
Old 02-15-2016, 04:26 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
I sure wouldn't mind getting some money back for the 7 drives which failed. Of the 10 I bought, the remaining 3 are still in service, but I'm confident they will be the next ones to fail. All 7 drives were replaced at least once and some up to 3 times before their warranties ran out and I replaced them with WD or HGST drives.
Software: SageTV 7
Old 02-15-2016, 06:19 PM
All of my failed Seagate drives had retail packaging. I've never purchased "bare" drives. Read too many reports how Newegg just lets the drive shift around in a box of peanuts, clearly contrary to the manufacturers packaging/shipping specs. Amazon is guilty of this too. I've seen first-hand how Fry's retail stores (mis)handle bare drives. Not worth the grief.
Old 02-17-2016, 05:45 PM
valnar valnar is offline
My Server all has 2GB WD Red or Samsung drives. My Backup NAS all has 5GB HGST drives. No problems. No Seagates anywhere.
Server: ASUS P7F-E, Intel Xeon x3440, 4GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 7TB disk,
2x Nvidia DualTV, 2x HDHomeRun, HD-PVR 1212, Win7-32bit, Sage 7 latest
Client 2: HD300 on Vizio 40"
Old 02-18-2016, 09:54 AM
mistergq's Avatar
mistergq mistergq is offline
As I am replacing drives, I'm replacing them with server rated HDs. I still have Seagates in the machine, but have been buying WD on replacement. I will probably consider HGST next time as well.
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS.
Client: Windows 10 Pro
Media Extenders: HD-200 x 3, HD-200 x 2
Old 02-19-2016, 07:19 PM
metapath's Avatar
metapath metapath is offline
Beware
After reading this thread, I ordered a 5TB Samsung external drive (USB3) and after unpacking, horrors! there was a Seagate warranty included. Evidently Samsung is using Seagate drives in their externals.
It was paid for by my company, and has 3 year warranty, so I'll hold my breath. (Not too long, I retire in 12 months!).
Old 02-19-2016, 08:46 PM
Samsung HDD division was purchased by Seagate a long time ago. There haven't been any true Samsung drives in a long time. The same thing happened when Seagate purchased Maxtor even longer ago. The Maxtor drives were replaced with a Seagate model and firmware but a Maxtor name on the drive.
Last edited by BobPhoenix; 02-20-2016 at 12:19 AM. Reason: added the HDD distinction
Old 02-19-2016, 10:12 PM
trk2 trk2 is offline
Originally Posted by BobPhoenix View Post
Samsung was purchased by Seagate a long time ago. There haven't been any true Samsung drives in a long time. The same thing happened when Seagate purchased Maxtor even longer ago. The Maxtor drives were replaced with a Seagate model and firmware but a Maxtor name on the drive.
Yeah, the Samsung HDDs are all Seagate's now But, the Samsung SSDs are still made by Samsung and they are excellent.
Old 02-20-2016, 12:14 AM
Opps. I should have made that distinction. Thanks.
Old 02-20-2016, 10:40 PM
panteragstk's Avatar
Isn't HGST owned by WD now?
I've had more WD drives fail on me than my Seageates. I read that the newer Seagates should be among the best. I've got 6 of them with no issues (one DOA due to shipping, but that isn't the manufacturer's fault).
I've seen failures on all manufacturers. I can't really tell who has lower rates and who doesn't.
The seagate 8tb archive drives are going to be my next purchase for a new unRAID build. Maybe I should ponder on that for a bit before my purchase.
Old 02-21-2016, 12:14 PM
Yes HGST is owned by WD. My worst failure rate and with the worst failure has been on a Seagate drive (worked fine for a couple of years and had a good smart report one day gone the next - bios didn't even see it). But I have had failures with all brands. HGST has been the best of currently selling drives followed by WD with Seagate barely worse than WD. Best drives in history were the genuine Samsung drives before Seagate bought them.
HD Fury Lawsuit reggie14 General Discussion 18 01-11-2016 03:40 AM
What is the Sage TV win class? jominor Hardware Support 4 05-22-2006 08:25 AM
