Old 05-21-2016, 02:12 PM
mwnswiss mwnswiss is offline
Send a message via Skype™ to mwnswiss
Linux Ubuntu 16.04 build error
I recently upgraded to Ubuntu 16.04 LTS and started a buildall.sh. I got an error about a bad gcc version "GCC 2.96 IS NOT AND WILL NOT BE SUPPORTED BY US !". It happens during the MPLAYER build. Anyone else having this problem?
Detected operating system: Linux
Detected host architecture: x86_64
Checking for cc version ... 5.3.1, bad
Checking for gcc version ... 5.3.1, bad
Checking for gcc-3.4 version ... not found
Checking for gcc-3.3 version ... not found
Checking for gcc-3.2 version ... not found
Checking for gcc-3.1 version ... not found
Checking for gcc3 version ... not found
Checking for gcc-3.0 version ... not found
*** Please downgrade/upgrade C compiler to version gcc-2.95, 3.x or 4.x! ***
You are not using a supported compiler. We do not have the time to make sure
everything works with compilers other than the ones we use.  Use either the
same compiler as we do, or use --disable-gcc-check but DO *NOT* REPORT BUGS
unless you can reproduce them after recompiling with a 2.95.x or 3/4.x version!
Note for gcc 2.96 users: Some versions of this compiler are known to miscompile
mplayer and lame (which is used for mencoder).  If you get compile errors,
first upgrade to the latest 2.96 release (minimum 2.96-85) and try again.
If the problem still exists, try with gcc 3.x (or 2.95.x) *BEFORE* reporting
bugs!
Error: Bad gcc version
Check "configure.log" if you do not understand why it failed.
Build failed, exiting.
Build MPLAYER failed, exiting.
Standard Intel PC with 4GB RAM Ubuntu 16.04 64bit
JVM version=1.8.0_121-b13 / SageTV V9 latest
HDHR DUAL EU with 2 DVB-C and HDHR EXPAND 4DC with 4 DVB-C
XMLTV using WebGrabPlus in Switzerland
Clients: HD200, Placeshift on OSX (limited) and Windows, Sage Android Client on ShieldTV and Tablets
Old 05-21-2016, 02:14 PM
Wrong alert! Of course I found the hint on the build page ... NOTE: If you are running Ubuntu 15.10+, mplayer will fail to build
linux
Comskip in Linux (ubuntu server) v9 ex-tivoman SageTV v7 Customizations 3 04-06-2016 09:35 AM
Problem building on Linux (not Ubuntu) ASegredo SageTV Github Development 12 10-13-2015 09:59 AM
Ubuntu 10.04.1 - Sage Server for Linux - Haupaugge 2250 shugrue SageTV Beta Test Software 3 10-15-2010 01:28 AM
Linux (Ubuntu 7.10) - Placeshifter font too long ltitran SageTV Linux 9 04-09-2008 06:00 AM
Ubuntu 7.04 and SageTv Linux 6.1 Box8489 SageTV Linux 7 06-01-2007 07:25 PM
