Old 11-13-2016, 12:23 PM
routerunner's Avatar
Question USB TV Tuner for DVB T/T2
Does anyone know of a USB TV tuner able to receive DVB T/T2 standard that definitely works with STV v7 please? I just need it for testing so has to be cheap.
Eddy
Old 11-13-2016, 03:04 PM
starfire starfire is offline
Hi Eddy try this
Which is this card I believe.
And just DVB-T only https://forums.sagetv.com/forums/sho...7&postcount=10
Old 11-14-2016, 06:00 AM
Stu Gare Stu Gare is offline
Hi, I have one of these going spare.
TBS PCI-E DVB-T2 Quad TV Tuner Card High Definition Digital Free to Air Tuner (DVB-T/DVB-T2)
Has been used for a couple of years, but my new case didn't include an additional PCIE power connector so I can no longer use this and replaced with a couple of HD HomeRuns.
Not USB, but perhaps could serve you for more than just testing.
Let me know if interested, I'd sell for a reasonable offer.
Regards
Stuart
1 SageTV Server (v9) ,
3 HD300,
2HD200,
HD-HOMERUN CONNECT(2xDVB-T2)x2,
1 HD-PVR2 (Gaming Edition)/SKY HD,
QNAP NAS
Old 11-14-2016, 01:32 PM
Originally Posted by starfire View Post
Hi Eddy try this
Thank you very much for the links, the Maplin was maybe right, but T only and discontinued .
I was more thinking about THIS to be honest, with the aerial included, considering that after testing it will be probably back to eBay at half price
Unfortunately it's a gamble because it all depends on the chipset being used to be natively supported by STV.
Regards
Stuart
Thanks for the kind offer, but it has to be USB because my development machine hasn't got any PCI-E slot left and after testing it will not have much use anyway.
Cheers
Eddy
Old 11-15-2016, 12:50 AM
deanm deanm is offline
Hi Eddy
I have 2 PCTV NanoSticks that are DVB-T2. They work well with STV
You can borrow/have one as at the minute they are not in use.
Dean
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 11-15-2016, 02:33 AM
Originally Posted by deanm View Post
Hi Eddy
Dean
Thanks Dean, eventually I bought one of THOSE last night, I like the fact that an active aerial is included as I don't have one on the roof. If the dongle doesn't work with STV I will borrow one of your PCTV NanoStick for few days if you don't mind.
Cheers
Eddy
Old 11-20-2016, 12:46 PM
Well, guess what? This USB tuner works with any DVB player I've tried, but no luck with STV
This tuner it's a truly BDA compliant device and STV should work well with BDA devices, however the tuner side of STV has never being its strong point. Maybe this is finally the time for the OS community to tackle this aspect.
Cheers
Eddy
Old 11-21-2016, 12:44 PM
Hi Eddy
Sent you an email
Dean
New Hauppauge WinTV-dualHD TV Tuner USB and Soon a Quad Tuner PCIe SHS Hardware Support 12 10-02-2016 11:07 AM
New Hauppauge CableCard Tuner for pre-order, shipping this month! $129 for dual tuner jptheripper Hardware Support 6 08-07-2011 12:15 PM
enabling channels on analog tuner also enables them on digital tuner LaoChe SageTV EPG Service 2 02-02-2011 08:09 PM
Added 2nd tuner (Hauppauge HVR-1600), no audio on analog, no digital tuner jtimmes SageTV Linux 4 02-02-2010 10:22 PM
HDTV Built-In tuner (Samsung 50" DLP) VS. Vbox 150 Tuner in PC? Generalg Hardware Support 3 07-17-2006 10:59 PM
