Old 07-13-2004, 10:21 PM
azcavalier azcavalier is offline
Send a message via ICQ to azcavalier Send a message via AIM to azcavalier
Adaptec AVC-2010 PCI issues
I had used an older version of Sage Recorder with an Adaptec AVC-2010 PCI card without problem, but after having some HD issues and a reformat and reinstall of Windows, I decided to purchase the newer SageTV Recorder.
When I start SageTV, I get the error message "There was a problem utilizing the specific capture configuration. Unable to connect analog video cross-streams." And then the program starts. It will not, however, let me switch video inputs to the composite or s-video inputs.
The website's only suggestion is that my card must not be supported. However, it is the same chipset as the supported AVC-2410 card that comes with the VideOh! DVD Media Center.
Suggestions?
Old 07-29-2004, 01:35 PM
Malc C Malc C is offline
I've just received my PCI Videoh! card that is also based on the 2010 card and not the older 2000 cards, and found that this is not supported by Sage Recorder (shame as it has been very well recommended)
Is there any updates to the software, or plug-ins in the pipeline that will work with these newer generation of cards
