Old 01-29-2017, 07:52 AM
jamesdisco's Avatar
jamesdisco jamesdisco is offline
Using Schedules Direct in UK
Is anyone using the new epg service with sky channels in the UK.
Ive signed up to schedules direct and had a play around with V9 the guide data looks far better than digiguide.
The computer i'm using sage V9 on doesn't have a satellite signal so i cant actually test properly.
My question is if i clear out the channel list schedules direct puts in and then drop in my own .frq(with all the sky channels) will it match up correctly and show the right epg data for the right channels.
Server: Win 10 64bit Core i3 8GB 20TB, TBS6985, TBS6984, Sage 9.
Clients: 5 x HD300, 2 x HD200, Placeshifter.
Old 01-30-2017, 04:09 AM
rickgillyon's Avatar
I'm using it with VM, but it doesn't work like that AFAIK. You get the lineup and hack your FRQ to match, or scan for your FRQ, delete your scanned lineup and add from SD, tweaking to make the lineup match the FRQ. I chose the latter approach.
Agreed it's definitely much better than previous EPG options though.
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.1, tvHeadEnd for recording back end, OpenDCT, SDEPG, SageTV 9
Clients: 3 Nvidia Shields, 1 FireTV, 2 Android Miniclients (Amlogic S905X), 3 Win10 Pro PC Clients
Old 01-30-2017, 05:02 AM
jamesdisco's Avatar
Thats a shame ive got used to Deanm's DDAC creating the .frq's for me, its been a while since ive had to mess on copy and pasting. It was bad enough doing it with DVB-T, now i'm on satellite it will take forever.
Old 01-30-2017, 06:30 AM
Not sure what you'd be copy/pasting, but it is a royal PITA on the first lineup. If you re-use that lineup for subsequent tuners, the FRQ file is copied automatically.
Old 01-30-2017, 07:01 AM
EnterNoEscape's Avatar
Can you provide me with an example of the custom FRQ file you're using and what lineup you're using it with? Sometimes Schedules Direct provides more information than SageTV can actually use and I'd like to see if any of that extra information could be used to help you out.
Old 01-30-2017, 09:05 AM
Is the channel list provided by SD not correct in the Sky lineup? or is there not a sky lineup?
Old 01-30-2017, 09:35 AM
I obviously can't really answer this question, but Schedules Direct does often have additional data for DVB. I need to see how this usually works to see if maybe I can optionally automatically generate these files when guide data is pulled down. Perhaps the answer to why things look a little off in other countries lays in some middle-ground that can be determined using all available information.
Old 01-30-2017, 09:51 AM
jamesdisco's Avatar
It looks correct to me, i was unable to do a channel scan as the machine i was on didn't have a cable attached. So i dont know if sage matches up the channels from the .frq to the epg correctly. Initial epg setup has always been a pain in the UK so it would be great if that were to happen.
Old 01-30-2017, 11:54 AM
Well, the 'goal' would be to not have to make a .frq file other than the default provided. The scan info returned to sage 'should' be enough for sage to match the scan results to the epg lineup.
Old 01-30-2017, 05:12 PM
deanm deanm is offline
I really wish this was the case. Thou to be honest I have not tried this and can't see how this would work as the .frq channel names don't match the data from SD.
Deanm
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 01-30-2017, 05:47 PM
As you know I did start creating DDACv2. This worked for DVB-T, DVB-C and DVB-S and worked very well. The reason I never released it was you had to manually maintain a CSV table that matched Channel Names and Channel numbers with the SID numbers for each of the DVB types.
The plus side to this was I could create a full channel scan in 2 mins and have everything renamed as I liked it and .frq files generated using EPG Collector to find the Channel SID numbers for each DVB type.
With a simple modification I was able to pull in the lineups from SD and remap my SD line up and create the matching .frq files.
I did have to use the Import/Export plugging (Cant remember proper name) to import the channel lines up. This was a bit of a hack but I had SD setup for over 250 channels within minutes for both DVB-T and DVB-C.
Unfortunately I don't use DVB-S anymore but I'm sure it would not take long to create the an SD file to import into SageTV.
If you send my your DDAC channel file I will see what I can do.
Deanm
Old 01-30-2017, 06:41 PM
Deanm
I would like to see a log of a scan, to analyze if it could be improved in the matching.
Old 01-31-2017, 01:52 AM
Sorry, my reply above was almost entirely wrong. My VM lineup uses external tuning, so no FRQ at all. My Freeview lineup works as I described, have to either manually hack the Frq to match lineup or lineup to match FRQ. FRQ attached, lineup is GBR-0001228-DEFAULT.
File Type: txt TBS 6284 BDA Digital Capture DVBT-1-DVB-T.txt (14.0 KB, 66 views)
Old 01-31-2017, 06:36 AM
Bummer. I don't see anything that could bring us better automation. It looks like we only have extra information about DVB-S. If someone has had issues with DVB-S and wants to share their lineup and FRQ file, I'll see what I can do with that.
Old 01-31-2017, 06:49 AM
jamesdisco's Avatar
Here's the .frq i'm using at the moment produced by DDAC.
File Type: txt TBS 6984 Quad BDA Digital Capture DVBS-0-DVB-S.txt (42.0 KB, 66 views)
Old 01-31-2017, 06:56 AM
What lineup would you have used for this?
Old 01-31-2017, 07:42 AM
jamesdisco's Avatar
Sorry, it's DVB-S Sky
I have it setup so that SD is preferred over HD so the channel nos. will be different to schedules direct for channels that are available in both.
Old 01-31-2017, 07:51 AM
What does Sage return if you do a scan in sage without the custom FRQ file? If you restart sage (to get into a new log file) and then go strait to a full channel scan, it should include the scan results in the log (I think). If you don't mind posting that, it would be helpful for us Yanks to get the full picture of what can be done.
Old 01-31-2017, 09:02 AM
Thanks again. Unfortunately it's starting to look like the only time I have advanced information about the frequencies and such is when the lineup is called DVB-S. Your tuner is most certainly DVB-S, but the information provided by Schedules Direct calls it Satellite which means it's pretty much assuming that you're tuning an STB and recording the playback. I was really hoping to be able to add something helpful.
Old 02-01-2017, 06:12 PM
jamesdisco's Avatar
Here's a channel scan from the UK its enormous with over 900 channels.
Ive no idea how to merge the scanned channels with the list from SD which has over 600 in the sky lineup. In the past i have always edited the frq with the correct channel nos. and then followed the instructions in this post.
Really hoping someone can find a way to make sage match up the scans with the SD list.
Schedules Direct EPG (integrated BETA) EnterNoEscape SageTV EPG Service 465 03-12-2019 06:26 PM
How to Migrate to Schedules Direct? reggie14 SageTV EPG Service 51 10-15-2017 07:34 PM
Plugin: Schedules Direct EPG (not for v9) Slugger SageTV v7 Customizations 851 07-19-2017 07:48 AM
Easing the transition to Schedules Direct wayner SageTV EPG Service 4 04-14-2017 03:16 PM
