Old 02-26-2019, 10:52 AM
deanm deanm is offline
Another SageX/API Question
Is it possible to use wildcards with the API?
For example I want to extract the following from the Sage.Propierties file.
epg_data_sources/6667813/unavailable_stations
Using the GetServerProperty API command I get the reply I need.
sagex/api?c=GetServerProperty&1=epg_data_sources/6667813/unavailable_stations&2=Error
But my issue is I need to know the ref number (6667813) for the command to work.
If you cant use wildcards how would I find the ref number? My current work around is to copy the Sage.Properties file and extract the number/line but wanted something a bit more elegant using SageX
Dean
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 02-26-2019, 12:51 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Dean
There are other APIs you can use to get properties that start with a specific item, in your case "epg_data_sources". I don't recall exactly but they are something like GetPropertiesThatAreBanches and GetPropertiesThatAreLeaves. You should look into using those.
Old 02-26-2019, 05:12 PM
Thank you for the pointers, yes this resolved my issue.
Cheers
Dean
sagex-api / sagex-services v9.1.7.0 stuckless SageTV v9 Customizations 11 03-16-2018 07:13 PM
Sagex API intelligent sort question bnh SageTV v9 Customizations 3 10-27-2017 06:13 PM
Sagex question - turning on extenders wayner SageTV v9 Customizations 9 09-15-2017 07:30 AM
sagex-api Plugin MISSING: sagex-api-FAILED http://ubuntone.com/5NNCHGlywxvXBgRw8B3nMr antplugger SageTV v7 Customizations 10 06-10-2014 01:34 AM
