Old 01-16-2006, 06:52 PM
FidgetyRat's Avatar
FidgetyRat FidgetyRat is offline
Client playback issues.
Hi guys. I need a bit of advice on this one.
I have an 833 Mhz system, 256Mb ram and fast ethernet. This system is running a very very clean and watered down win2k and is ONLY being used as a client.
My video play back skips every 2 seconds, uses 100% CPU, and any mouse or keyboard presses take @12 seconds to register.
If i stream a DivX file it runs perfectly fine around 50% CPU.
Anyone know what I can do to get this working? 833 is morer then enough to watch video. Especially if DivX files are streaming perfectly fine at 1/2 the cpu drain.?
Server: 2.6Ghz Pentium Dual Core, 2GB RAM. 3x PVR-150, 1.5TB HDD. Geforce 7300GS, Sage 7.0.15
Client: Jetway ION-Top - Dual core ATOM 1.6 & NVIDIA ION
NAS: QNAP TS-419P 3.7TB Raid-5
Special thanks to tmiranda for making my 24h time format dream a reality. See here for more details.
Old 01-16-2006, 06:55 PM
Wheemer's Avatar
Wheemer Wheemer is offline
Mpeg2 is a lot harder to decode and playback then xvid. What decoder are you using and what video card?
Old 01-16-2006, 07:02 PM
FidgetyRat's Avatar
Hmm didnt know that.
Using default sageTV decoder on an onboard video. I know a better video card would help but its a very tiny system and it cant be replaced.
Would a different mpeg decoder help? If so any suggestions as to which?
I do have some DVD programs that may have different decoders.
Thanks again. I'm mainly looking for ways to squeeze better performance out of the system I already have which met all of sageTVs requirements.
Old 01-16-2006, 07:39 PM
Wheemer's Avatar
well I know some decoders may work with certain video hardware better than others... Give the Nvidia Purevideo decorder a whirl, there's a 30 day trial.
Old 01-16-2006, 08:59 PM
stevech stevech is offline
My Client has those same symptoms - lots of dropped frames in batches every few seconds and 10 second lag in responding to key-presses. This PC has a very crude video card (mobo video) so I guess I blame it on an overtaxed CPU decoding MPEG and reformatting for this video display. I haven't tried a $50 class PCI bus video card yet.
Clent: AMD 1800 with 512M ram, XP Pro
Server: AMD 2400 with 1G ram
Old 01-16-2006, 09:44 PM
FidgetyRat's Avatar
I moved all of the decoder options to "Default" and the CPU runs at about 84% now so I am guessing the problem was with the sageTV decoders.
I actually have no idea what my "default" decoder actually is. I tried to install a new encoder that is supposedly easier on the cpus "Elecard MPEG-2" however I don't have the option to use it in sage? Do i need to add lines to config files?
So far at least I can play the files. Menus activate in about 1 second now instead of 12 so thats improvement.
Im going to try 800x600, hopefully ease up on the frame buffer a bit.
Old 01-17-2006, 10:05 AM
ben_95sl1 ben_95sl1 is offline
I'm using a p3-600 with an ati rage pro 8mb pci card on winxp, and runs just dandy; people have less and still worked. it played skip free with windvd, powerdvd and sage decoders (and I think the sage one probably doesn't have option for hwmc, or dxva support from the video card). Mind you, its not a rocket, but playback is fine. I've found that dxva/video card accel isn't defaulted when using the decoders(need a reg setting); and even your onboard video might have some mpeg2 accel (so find out if it does and enable it in the decoder)
Server: XP SP3, X2 BE 5000+, WD 1.5TB x 2, PVR150 & HD-PVR, USB-UIRT
Clients: HD300, HD100 x 2, Media MVP in a box somewhere
Old 01-17-2006, 12:01 PM
FidgetyRat's Avatar
Thanks. Things are running much better with "default" decoders instead of the sageTV decoders
You mentioned that I may be able to "enable it in the decoder". How do you go about doing something like this.
Also, how tell sageTV where to find new decoders. I downloaded a different software decoder that is supposed to be much better on a cpu but sage only allows me to select "default" or "sage decoder"
Also, i do have winDVD and powerDVD but they are not installed. would they benefit the system with better codecs if installed?
Old 01-17-2006, 12:43 PM
you're pvr250 cards should have come with intervideo non-css decoders on the install disk - which I believe are windvd decoders but don't work on CSS encrypted mpeg2s (DVD). I use those and they work great with dxva/hwmc enabled (which may or not make a difference with your onboard video). there's a thread stickied at the top of the hardware section for how to enable. Windvd is simlar, don't knwo about powerdvd.
Old 01-17-2006, 12:48 PM
FidgetyRat's Avatar
Thanks alot. I have a bunch of different DVD software and the hauppauge disks. Ill give some of them a shot..
Will sageTV display these different codecs in the setup?-
Old 01-17-2006, 01:08 PM
here's the thread I meant...apparently its not where i thought it was...
http://forums.freytechnologies.com/f...video+cpu+dxva
