Old 06-30-2007, 07:13 AM
PhillJones PhillJones is offline
How to fix ripped DVD playback issues
I've been experimenting with copying DVDs to the HDD and playing them back and I've run into a problem.
The only DVD I've tried gets to a certain point and just hangs. Sage is totally unrecoverable and I have to turn the PC off to regain control. The issue seems to be that purevideo is balking at this file at a specific place. I've tried the file in WMP and it hang in the same place each time. It plays fine in vlc so obviously the file isn't totally borked.
The problem is that I need purevideo as it's the only decoder that'll playback HD recordings without stuttering.
Hos do you deal with issues like this? I've heard about an mpeg cleanup programme, maybe that'll help?
AMD Athalon 2400-M (2200MHz) 1Gb memory, nVIDIA 6600GT fanless, 1x300Gb pata, 1x500Gb sata, PVR-150MCE, Motorola cable box: firewire recording, MCE 2005 remote (OEM), Windows MCE2005, Sage v5.0.4, SageMC v6.13a, Pioneer PDP503-CMX 50" Plasma, HK630 HT receiver
Wish List: BBC radio player, AR correction in photo viewer, Netflix Watch Now
Old 06-30-2007, 12:41 PM
popechild popechild is offline
Since it sounds like you've only tried one and it's hanging at the same place, why don't you just try to re-rip that particular dvd?
Old 06-30-2007, 12:47 PM
tmiranda's Avatar
tmiranda tmiranda is offline
You could also look into running the VOBs through VideoReDo's "quick stream fix" function. That program works wonders for me, it fixes everything from sync issues to broken GOPs. My wife quipped that she was thinking about asking the authors of VideReDo to make "HusbandReDo". I told her that was asking way too much of them and her only hope was to reauthor her spouse
Old 06-30-2007, 04:54 PM
VideoReDo, that was what I was thinking of. I'll take a look at it.
Old 06-30-2007, 05:07 PM
This is more than a technical excercise to proove it can be done in principle. If I have to re-rip mulitple times to get a version that works, it'll be no use to me.
Old 07-01-2007, 06:18 AM
With the second rip, I get the same hang at the same place. If you leave sage for half an hour or so it finally gives the error message 'Insufficient Memory'.
Old 07-01-2007, 08:38 AM
Maybe try FixVTS.
Old 07-01-2007, 05:50 PM
Originally Posted by stanger89 View Post
Maybe try FixVTS.
Thanks for that pointer, i'll definately try that.
SageTV V6.1.7 Release Candidate Narflex SageTV Beta Test Software 1 04-05-2007 12:26 PM
DVD Playback is Dark on TV rmbu Hardware Support 2 02-11-2007 10:40 AM
No Audio with Sage dvd playback tsitalon1 SageTV Software 2 11-04-2006 10:50 PM
DVD playback error tasdisr SageTV Software 3 02-26-2006 02:20 PM
