Old 04-22-2008, 10:51 PM
Ender Ender is offline
DVD Playback issues after Clean install
Recently I had to do a complete reinstall of windows due to a corrupt archive during a restore operation. I have just installed Sage 6.3.10 I use Power DVD 7 for video codecs, AC3 filter for Audio, And ATI 8.4 hotfix drivers for my AGP 2600 pro.
Now here is the meat of the issue, with either my old ripped DVD's or those from disk, sage kicks outh the following error:
sage.PlaybackException: ERROR (-7,0x8): This DVD cannot be played due to region restrictions.
Now Power DVD, and Nero have zero issues with these same files, or disks.
Anyone have an Idea where I went wrong?
System Specs as of current:
(Due to ATI's unwillingness to fix AGP support I will be upgrading soon)
Intel 2180 Pentium Dual core processor
2GB DDR Ram
Asrock 4Core Dual SATA-2 Motherboard
Visiontek 2600 Pro AGP, 8.4 Hotfix drivers, (prior I was using 8.1, or 8.2s)
The usual suspects (HD DVD, DVD ROM, HDD'S (Several) )
and 2x HVR-1600
And to think all this could have been avoided if my backups were not corrupt, possibly a bad drive.
Old 04-23-2008, 08:19 AM
A good rule of thumb I use is always install your favorite decoder last. Why? Last one installed usally becomes the default. Make sure in Sage in Detailed setup and under DVD that you have specifically chosen the Cyberlink decoder. You may have Cyberlink set for your video codecs but you need to specify them for the DVD also.
Old 04-24-2008, 10:01 PM
I made sure Cyberlink decoders are the default in windows, Sage has Cyberlink decoders set for both video, and DVD. I have tried region free material, regular DVDs all I seem to get is errors.
Regular DVDs I get a Macrovision, or CSS error, but Power DVD, and Windows media player pick it up just fine. I have a few more experiments to try, but at this point, I may just have to re install sage and see if that fixes it.
Old 04-25-2008, 07:08 AM
Just for grins and giggles reboot the whole server and try playing it again.
Old 04-27-2008, 11:18 PM
I am at a complete loss now. I was able to do this last week before my tweaking nature got the best of me, and my backups were corrupt.
I am now able to play any actual DVD through sage, but if I have the VOB files on the hard drive, which I do as a matter of routine for my library, (much easier than digging for the physical media) I get the region restriction error in Sage, but Both Nero Showtime, and Power DVD 7 will play the files without complaint.
All the files are marked as region free, or for all regions. Now actual DVDs marked the same way will play, just not files on the drive.
Old 04-27-2008, 11:22 PM
Tried that, re installed PDVD, etc.. etc... no joy.
I guess when I get the time I shall re install SAGE. I wonder if my issues are as simple as I deactivated UAC this time around because I find it annoying, and not worth my time.
When I get a moment I will post a copy fo a sage debug log, maybe someone can make sense of it.
Old 05-03-2008, 10:40 PM
I have tried installing an older version of Power DVD, re installed sage, but I did not delete the folder before re installation, so i am not sure if some remnants are mucking things up.
well here is a snippet of a debug log whilst trying to play a DVD video:
Sun 4/27 1:25:06.246 VideoFrame.watch(A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0])
Sun 4/27 1:25:06.246 watchThisFile=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]]
Sun 4/27 1:25:06.247 Watch airing is a file & over, do that instead dvd=false
Sun 4/27 1:25:06.247 Seeker.finishWatch(UIManager:localhost@@SAGETV_PROCESS_LOCAL_UI-1cd2e5f)
Sun 4/27 1:25:06.248 VF.submitJob(VFJob[WatchMF r=0.0 t=0 file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] ifn=null])
Sun 4/27 1:25:06.249 VF processing job VFJob[WatchMF r=0.0 t=0 file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] ifn=null] nPlayin=false
Sun 4/27 1:25:06.251 VF processing on UI Thread VFJob[WatchMF r=0.0 t=0 file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] ifn=null]
Sun 4/27 1:25:06.251 VideoFrame creating new media player for file:MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]]
Sun 4/27 1:25:06.254 VF processing job VFJob[LoadMF r=0.0 t=0 file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] ifn=null] nPlayin=false
Sun 4/27 1:25:06.255 VF processing on UI Thread VFJob[LoadMF r=0.0 t=0 file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] ifn=null]
Sun 4/27 1:25:06.256 VF file=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] targetTime = Thu 2/21 22:16:37.411
Sun 4/27 1:25:06.256 VideoFrame.timeSelected(Wed 12/31 19:00:00.000, true) currFile=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]]
Sun 4/27 1:25:06.258 DShowPlayer setVideoRendererFilter0({51B4ABF3-748F-4E3B-A276-C828330E926A}) called
Sun 4/27 1:25:06.272 Setting up VMR9 deinterlacing
Sun 4/27 1:25:06.272 Curr Mix Prefs=0x1015
Sun 4/27 1:25:06.272 Set to 0x2015, hr=0x0, New Mix Prefs=0x2015
Sun 4/27 1:25:06.273 DShowPlayer setVideoDecoderFilter0(CyberLink Video/SP Decoder (PDVD7)) called
Sun 4/27 1:25:06.373 DShowPlayer setAudioDecoderFilter0(AC3Filter) called
Sun 4/27 1:25:06.398 Increased hash Map pool to size=9
Sun 4/27 1:25:06.434 NATIVE RenderAudio called stream=1
Sun 4/27 1:25:06.434 NATIVE RenderAudio step 1
Sun 4/27 1:25:06.434 NATIVE RenderAudio step 2
Sun 4/27 1:25:06.434 NATIVE RenderAudio step 3
Sun 4/27 1:25:06.434 NATIVE RenderAudio step 4
Sun 4/27 1:25:06.440 setUI(sage.b1@5be8f4[MC MediaPlayer OSD]) histIdx=3 uiHistory=[sage.b1@8f83a9[Dynamic Menu by nielm], sage.b1@932892[Video Library Folder View], sage.b1@15b2f17[Program Info], sage.b1@5be8f4[MC MediaPlayer OSD]]
Sun 4/27 1:25:06.440 Ticker enabled
Sun 4/27 1:25:06.562 NATIVE RenderVideo called
Sun 4/27 1:25:06.562 NATIVE RenderVideo step 1
Sun 4/27 1:25:06.563 NATIVE RenderVideo step 2
Sun 4/27 1:25:06.563 Video source pin information:
Sun 4/27 1:25:06.563 PIN is not connected yet!Sun 4/27 1:25:06.563 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.563 Interlaced video
Sun 4/27 1:25:06.563 Both fields per sample
Sun 4/27 1:25:06.563 Field 2 first
Sun 4/27 1:25:06.563 Stream never contains a Field 2
Sun 4/27 1:25:06.563 Either bob or weave mode.
Sun 4/27 1:25:06.564 Both fields per sample
Sun 4/27 1:25:06.564 Field 2 first
Sun 4/27 1:25:06.564 Stream never contains a Field 2
Sun 4/27 1:25:06.564 Either bob or weave mode.
Sun 4/27 1:25:06.564 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.564 Interlaced video
Sun 4/27 1:25:06.565 Stream never contains a Field 2
Sun 4/27 1:25:06.565 Either bob or weave mode.
Sun 4/27 1:25:06.565 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.565 Interlaced video
Sun 4/27 1:25:06.565 Both fields per sample
Sun 4/27 1:25:06.565 Field 2 first
Sun 4/27 1:25:06.566 Weave display mode only.
Sun 4/27 1:25:06.566 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.566 Interlaced video
Sun 4/27 1:25:06.566 Both fields per sample
Sun 4/27 1:25:06.566 Field 2 first
Sun 4/27 1:25:06.566 Stream never contains a Field 2
Sun 4/27 1:25:06.567 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.567 Interlaced video
Sun 4/27 1:25:06.567 Both fields per sample
Sun 4/27 1:25:06.567 Field 2 first
Sun 4/27 1:25:06.567 Stream never contains a Field 2
Sun 4/27 1:25:06.567 Weave display mode only.
Sun 4/27 1:25:06.567 M type MEDIATYPE_Video  S type MEDIASUBTYPE_NV12 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.567 Either bob or weave mode.
Sun 4/27 1:25:06.567 M type MEDIATYPE_Video  S type MEDIASUBTYPE_IMC3 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.568 Interlaced video
Sun 4/27 1:25:06.568 Both fields per sample
Sun 4/27 1:25:06.568 Field 2 first
Sun 4/27 1:25:06.568 Stream never contains a Field 2
Sun 4/27 1:25:06.568 Either bob or weave mode.
Sun 4/27 1:25:06.568 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YV12 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.568 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YUY2 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.569 Field 2 first
Sun 4/27 1:25:06.569 Stream never contains a Field 2
Sun 4/27 1:25:06.569 Either bob or weave mode.
Sun 4/27 1:25:06.569 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YUY2 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.569 Interlaced video
Sun 4/27 1:25:06.569 Both fields per sample
Sun 4/27 1:25:06.569 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YV12 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.570 Either bob or weave mode.
Sun 4/27 1:25:06.570 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YVYU F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.570 Interlaced video
Sun 4/27 1:25:06.570 Both fields per sample
Sun 4/27 1:25:06.570 Field 2 first
Sun 4/27 1:25:06.570 Stream never contains a Field 2
Sun 4/27 1:25:06.570 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB24 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.571 Either bob or weave mode.
Sun 4/27 1:25:06.571 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB32 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.571 Interlaced video
Sun 4/27 1:25:06.571 Both fields per sample
Sun 4/27 1:25:06.571 Field 2 first
Sun 4/27 1:25:06.571 Stream never contains a Field 2
Sun 4/27 1:25:06.571 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB555 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB565 F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.572 Interlaced video
Sun 4/27 1:25:06.572 Both fields per sample
Sun 4/27 1:25:06.572 Field 2 first
Sun 4/27 1:25:06.572 Stream never contains a Field 2
Sun 4/27 1:25:06.572 Either bob or weave mode.
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YUY2 F type FORMAT_VideoInfo
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YV12 F type FORMAT_VideoInfo
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_YVYU F type FORMAT_VideoInfo
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB24 F type FORMAT_VideoInfo
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB32 F type FORMAT_VideoInfo
Sun 4/27 1:25:06.572 M type MEDIATYPE_Video  S type MEDIASUBTYPE_RGB555 F type FORMAT_VideoInfo
Sun 4/27 1:25:06.573 NATIVE RenderVideo step 3
Sun 4/27 1:25:06.588 VMR9 alloc 720x540 Offscreen DefaultPool  format=NV12 minBuffs=1 arx=4 ary=3 nativeWidth=720 nativeHeight=540 reqNumBuff=1 allocNumBuff=1 hr=0x0
Sun 4/27 1:25:06.589 Setting up VMR9 deinterlacing
Sun 4/27 1:25:06.589 WIN32 FAILURE HR=0x8876086c FILE=.\CPlayerData.cpp LINE=1035
Sun 4/27 1:25:06.590 WIN32 FAILURE HR=0x8876086c FILE=.\CPlayerData.cpp LINE=1035
Sun 4/27 1:25:06.591 WIN32 FAILURE HR=0x8876086c FILE=.\CPlayerData.cpp LINE=1035
Sun 4/27 1:25:06.592 WIN32 FAILURE HR=0x8876086c FILE=.\CPlayerData.cpp LINE=1035
Sun 4/27 1:25:06.592 Actual deinterlace: hr=0x0 guid={3C5323C1-6FB7-44F5-9081-056BF2EE449D}
Sun 4/27 1:25:06.592 deinterlace mode: hr=0x1 guid={00000000-0000-0000-0000-000000000000}
Sun 4/27 1:25:06.592 Setting deinterlace mode to actual mode...
Sun 4/27 1:25:06.592 deinterlace mode: hr=0x0 guid={3C5323C1-6FB7-44F5-9081-056BF2EE449D}
Sun 4/27 1:25:06.592 Filter Graph Video Renderer Info:
Sun 4/27 1:25:06.592 Video Renderer:CLSID_VideoMixingRenderer9
Sun 4/27 1:25:06.593 M type MEDIATYPE_Video  S type Unknown GUID Name F type FORMAT_VideoInfo2
Sun 4/27 1:25:06.593 Interlaced video
Sun 4/27 1:25:06.593 Both fields per sample
Sun 4/27 1:25:06.593 Field 2 first
Sun 4/27 1:25:06.593 Stream never contains a Field 2
Sun 4/27 1:25:06.593 Either bob or weave mode.
Sun 4/27 1:25:06.596 VMR9 filter detected, using line 21 decoder 2.
Sun 4/27 1:25:06.600 DShowGraphFilters=Default DirectSound Device,VidRend,Line21 Decoder,Audio Decoder,Video Decoder,DVD Navigator,
Sun 4/27 1:25:06.601 VideoFrame.timeSelected2(Wed 12/31 19:00:00.000, true) currFile=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]] realDur=7200000
Sun 4/27 1:25:06.601 Running the playback graph.
Sun 4/27 1:25:06.601 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:06.624 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:06.625 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:07.436 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:07.437 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:07.438 VF.submitJob(VFJob[DirectControl r=0.0 t=0 file=null ifn=null])
Sun 4/27 1:25:07.440 VF processing job VFJob[DirectControl r=0.0 t=0 file=null ifn=null] nPlayin=true
Sun 4/27 1:25:07.443 VF processing on UI Thread VFJob[DirectControl r=0.0 t=0 file=null ifn=null]
Sun 4/27 1:25:07.444 Event: 0xd
Sun 4/27 1:25:07.444 Event: 0x104
Sun 4/27 1:25:07.444 Reading comskip settings
Sun 4/27 1:25:07.444 Event: 0x106
Sun 4/27 1:25:07.445 Event: 0x102
Sun 4/27 1:25:07.445 Event: 0x10c
Sun 4/27 1:25:07.445 DVD Event: Error event received (code 8)
Sun 4/27 1:25:07.445 fav=null
Sun 4/27 1:25:07.446 Built:sage.PlaybackException: ERROR (-7,0x8): This DVD cannot be played back due to region code restrictions.
Sun 4/27 1:25:07.446 airing=MediaFile[id=1488297 A[1488299,1488298,"310 to yuma/MainMovie/310 TO YUMA/VIDEO_TS",0@0221.22:16,0] host=Theater-PC encodedBy= format=null K:\DVD Video\310 to yuma\MainMovie\310 TO YUMA\VIDEO_TS, Seg0[Thu 2/21 22:16:37.411-Thu 2/21 22:16:37.412]]
DVD Playback issue: No cursor in root menu cmf SageTV Software 8 03-17-2008 02:27 PM
DVD Playback on a 2600 Pro AGP Ender Hardware Support 0 09-24-2007 03:43 AM
Playback issues with xvid files Tim M SageTV Software 0 03-31-2007 12:24 AM
DVD playback annoyances dmidtbo SageTV Software 3 02-03-2006 05:22 PM
