Old 05-22-2010, 04:47 AM
ThePaladinTech's Avatar
ThePaladinTech ThePaladinTech is offline
New Build with Sage7 - Win7 or no? 64bit or 32bit?
Well something made my Sage server go katty wompus last week. And I am now home where I can work on it. I have a question for everyone-
As I am reloading is there any real reason to go with Windows 7 Home (as it would be the best I could afford) versus my existing Windows XP Pro ??
And while at it I could go 64bit if I was buying 7 ... my thoughts on that are that I outta stick with 32bit for driver support.
note: I do not use my sage server for viewing
in the server setup I am using: haupauge media HD PVR, MCE500, Silicon Dust HD HR.
Thoughts? and thanks in advance. Kinda bizzare my server flaked out... it WANTED beta software loaded
(current) SageServer: SageTV Open Source V9 - Virtual Ubuntu on Win10 HyperV MSI 970A-G46, AMD FX-8370 , SD Prime via OpenDCT, Donater ComSkip
Clients: HD-200, Nexus Player w/ Android miniclient
Storage: "nas" 16 drive Win10 w/ DrivePool running Plex, Emby, & SD PVR
Retired - Hava, MediaMVP, HD-100, HD-PVR, HVR-2250, Ceton InfiniTV4, Original (white) HDHomeRun Died - HD-100, HD-300
Old 05-22-2010, 06:18 AM
PLUCKYHD PLUCKYHD is offline
Are you going to be using it at all besides sage?
It is hard for me to recomend xp to anyone these days Windows 7 offers so much and as well I always recomend 64 bit why not go with the future the compatabilitie issues with 64 bit are becoming less and less every day.
Old 05-22-2010, 06:21 AM
fac13 fac13 is offline
If all you want is an o/s to run Sage then I'd say stay with XP. This despite the fact that I run 64 bit Windows 7.
Sage will run just as well on XP, particularly as you don't want to use the server for viewing. If you change your mind on that, and want HD on that machine, then the bundled H.264 stuff in Win7 might tip the balance.
Next time you change o/s I personally recommend you go 64 bit; most hardware has drivers now and more memory is going to be a good thing in the longer term. Lots of people will tell you otherwise though ...
Old 05-22-2010, 08:18 AM
Plucky- I do not use it for a thing beyond SageTV - To clarify:
SageTV, Stuckless BMT, JReichen's WEb Server, Phoenix Fanart, ShowAnalyzer, Plucky's Movie Wall, Razrsharpe's TV Explorer, Evil Penqiuins Hulu netfilx, Dyndns updater... I think that is it. as long as it 'works' it just sits. but it's doing a lot.
And yeah, I've got 8g in this box - mostly wasted due to 32bit os. guess maybe it is time to make the switch.
Old 05-22-2010, 08:19 AM
sic0048 sic0048 is offline
Unless you see a need for firewire channel changing (which only works on 32bit), I'd recommend Windows 7 64bit.
No need to stick with XP - it's at the end of it's life and Windows 7 is so much better.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 05-22-2010, 08:24 AM
Thank you all for your quick responses and insight! I've already installed sage7 beta on my laptop and wow... (had to see it, and lappy is a multimedia model)
So one last question - what about home server? can I do EVERYTHING with it? it might make even more sense as I do not use the machine for anything other then ALL my sage duties??
HHmmmm think I answered my own question - WHS is only 32bit. so it can't address the memory either. new whs coming out sometime 2010...
Old 05-22-2010, 09:01 AM
I use WHS for my Sage setup because it allows me to only run one machine 24/7. However, the biggest issue with using WHS is the fact that you are unable to backup the WHS server itself. This is being fixed in the new WHS V2 - called Vail. But if you use WHS v1, then you either won't have the Sage system backed up, or you have to find another method to back it up "manually".
SageTV works just fine on a WHS system however for recording purposes. Since WHS is not designed for media playback, there might be something missing if you hope to use it as a SageTV client. I use extenders exclusively to access my media, so I have no need to use WHS as a client. It works great in my situation.
SageTV v9 (64bit)
OpenDCT
Hauppauge 2250 no channels in Win7 64bit dvd_maniac Hardware Support 2 03-28-2010 09:34 AM
Windows 7 64bit or WHS 32bit? nebulink General Discussion 20 03-08-2010 12:40 AM
HD-PVR + 32bit Win7 almazza Hardware Support 1 02-23-2010 08:06 PM
Problem when running in Win7 64bit rdefino SageTV Software 1 11-30-2009 12:47 PM
64bit processors with 32bit OS Question Stuntman Hardware Support 8 09-08-2006 10:12 AM
