Old 06-13-2010, 07:03 AM
Hauppauge 2250 IR Blaster
I have built a new machine and installed a new Hauppage 2250 in it to test Sage 7. I have everything working with the exception of getting SageTV to control the Happauge IR Blaster so I can use a set top box with S-Video. Everything seems to be configured correctly on both the Hauppage side and the SageTV side.
I can see video from the set top box on SageTV Just fine. If I open BlastCFG (Hauppauge Blaster config Application) on the SageTV Server and force channel changes with BlastCfg, they change on th set top box and on SageTV. However, if I try to change channels on the SageTV Gui, though the channel number changes in the sage display, it appears nothing gets sent to the blaster to actually make the box change channels so the channel being presented does not actually change.
SageTV recognized the blaster in the config options and loaded it fine. Are there any steps I have missed??? What will make this work??? Help......
Old 04-05-2013, 01:32 PM
dmelnyk dmelnyk is offline
Did you ever find solution
I realize this was an old post ... was there a resolution? I have the same problem now that I have had to go to STBs with Rogers Cable in Canada
Best regards, Dave Melnyk
HDHomeRun vs Hauppauge 2250 Diego Garcia Hardware Support 16 02-11-2010 10:22 PM
happague 2250 and 1800.. ir blaster bb11usa Hardware Support 0 01-22-2010 01:02 AM
Hauppauge 2250 question wolverines Hardware Support 1 12-25-2008 10:06 AM
WinTV-HVR-2250 IR Blaster ktriebol Hardware Support 2 11-07-2008 03:32 PM
SageTV and Hauppauge 2250 codiac Hardware Support 4 09-20-2008 08:36 AM
