Old 06-12-2011, 01:44 PM
SteveD's Avatar
SteveD SteveD is offline
SageTV Mobile Web Interface Version 2.1.0
Is there anyway to add links for other webpages to SageTV Mobile Web Interface.
Serv:ECS H61H2-T1 ITX I7 3770S CPU@3.1GHZ 8G Ram WIN1064 HDPVR, HD Homerun|network encoder Unraid Server:B75MU3B I5-3550 CPU@3.30GHz 9TB 16G Ram|Network HDPVR encoder:Win10 VM 8G Ram with Processor passthrough. Directv Http tuning to Genie, exemultitunplugin to Genie client. Http scheduled task bat file to defeat screensaver on Genie. Usb uirt scheduled task bat file to defeat screensaver on Genie client. Clients Android TV, Samsung TAB A
Old 06-12-2011, 02:04 PM
PiX64's Avatar
PiX64 PiX64 is offline
U would have to modify the code directly.
Where would u want to add links, and to what if u don't mind me asking.
Old 06-12-2011, 03:08 PM
SteveD's Avatar
Want to add links for my webcams. I don't want to bookmark separate links. I use yawcam.
Old 06-12-2011, 03:44 PM
PiX64's Avatar
Afaik u would have to modifying code. Once modified u would need to push a dev package to your server. Everytime we push out a new build your changes would be lost. I'll talk to jreichen to see if we can cone up with something for ya... U could make a standard HTML page with links and throw it in it's own jetty context. From there u could go to the web ui... Not the most elegant but a quick and dirty solution..
Old 06-12-2011, 04:32 PM
SteveD's Avatar
So if I create a html page, I can locate it here C:\Program Files\SageTV\SageTV\jetty\contexts and access it through the web UI. Do I have to edit anything in the UI to see the added links.
Old 06-12-2011, 04:56 PM
Fonceur's Avatar
Fonceur Fonceur is offline
So what exactly do you gain compared to just bookmarking the webcam?
SageTCPServer (2.3.5): Open source TCP interface to the SageTV API
MLSageTV (3.1.8)/Sage Media Server (1.13): SageTV plugin for MainLobby/CQC
TaSageTV (2.58)/TaSTVRemote (1.14): Monitor/control SageTV with an Android device
TbSageTV (1.02)/STVRemote (1.11): Monitor/control SageTV with a PlayBook 2
TiSageTV (1.64)/TiSTVRemote (1.09): Monitor/control SageTV with an iPhone/iPod/iPad
Old 06-12-2011, 05:06 PM
SteveD's Avatar
One page on my smartphone to look for my links.
Old 06-13-2011, 07:23 AM
PiX64's Avatar
I believe so yes, but im not 100% sure how jetty handles that. you may need some additional files in order for it to work. If i get sometime today during the day i will look for you and see if there is an easy way to do it.
Old 06-13-2011, 01:20 PM
The way that I have dealt with this is that I have a customized home page on my WHS box. This includes links to my home cameras as well as to my Jetty Pages (I have a regular and backup server). So it does require another click or two but it is not too bad to deal with.
Old 06-13-2011, 02:07 PM
jreichen's Avatar
jreichen jreichen is offline
I don't think you'll want to put anything in the jetty/contexts folder. That would require creating a more complex web application.
For simpler content you can put files in the jetty/static directory or subdirectories in there. For example, if you create the file jetty/static/webcams.html, you can access it at the URL http://<server>:<port>/webcams.html.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun.
Extender: STP-HD300, Harmony 550 Remote,
Netgear MCA1001 Ethernet over Coax.
SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client
, Java 1.6.
Plugins: Jetty, Nielm's Web Server, Mobile Web Interface.
Old 06-13-2011, 02:33 PM
PiX64's Avatar
Thanks for correcting my erroneous post jreichen! i knew there was a way to do it but couldn't quite remember, and haven't had a chance to look at it yet.
thanks again!
Old 06-13-2011, 08:05 PM
SteveD's Avatar
Installed a copy of Abyss Web Server X1. Configured it for port 80. Created a webpage with links to Webcams and sage mobile web.. Now I don't have to remember any ports. Just point to my dyndns address to get the page.
Plugin: Mobile Web Interface Version 2 jreichen SageTV v7 Customizations 383 04-23-2018 09:12 AM
Support: Mobile Web Interface V2 iOS Streaming jreichen SageTV v7 Customizations 225 09-22-2013 01:19 AM
Plugin: Mobile Web Interface 1.2 jreichen SageTV Customizations 281 06-17-2011 02:20 PM
FAQ: Mobile Web Interface V2 iOS Streaming jreichen SageTV v7 Customizations 3 11-07-2010 08:28 PM
Wanted: Developer for Web Interface Mobile Brent SageTV Customizations 249 02-09-2009 11:21 PM
