Old 02-19-2012, 09:39 AM
graywolf's Avatar
graywolf graywolf is offline
VideoRedo & Sage Timelines
Been playing with VideoRedo (trial) on my Sage recordings (SD mpg) to cut out the commercials for those recordings that I will keep.
Got comskip working well (almost dead on for several channels/shows) to output vprj files
Been playing around with VAP some and like it, helps doing stuff in batch so all I have to do is verify/correct any cut points.
I have been moving the original mpegs to location Sage does not know and put the cut/edited version (same name) back in original location. Perform a full library scan.
All is well EXCEPT the timeline which still shows 1hr (+- padding).
Is there a way to correct the timeline so sage shows the actual timeline?
Also, not show/start a minute or two into the show (based on original padding of recording)?
Especially for shows that I only care about keeping a particular story on so could only be about 15-20mins of a show.
Old 02-19-2012, 10:06 AM
jorton jorton is offline
Maybe the 1 hour duration is coming from the embedded metadata???
Off topic - does anyone know how to remove the embedded metadata? Or turn it off so it is not generated?
Old 02-19-2012, 10:31 AM
HelenWeathers's Avatar
The length of the program is in the metadata as i.e. AiringDuration=1800000
(1800000 / 1000(msec) / 60 (sec) = 30 min for a half hour program)
I've had success editing this info with a hex editor for programs I've edited, renamed and then imported.
I use HxD Hex Editor.
I have never tried removing the metadata entirely, only editing.
Old 02-19-2012, 12:34 PM
KryptoNyte's Avatar
Is there any other way for non-Sage software to retrieve the file metadata? Apparently it's not in any known format?
(Graywolf, I have the same issue. I'm also using VAP for VideoRedo to automate the process, rename the files to what I want, encode the files, and drop them in their respective show folders)
another btv to sage question: how are editted files from VideoReDo added? mistergq SageTV Software 7 01-12-2008 01:50 PM
Tinelines, timelines, timelines... Polypro SageTV Beta Test Software 3 09-13-2007 10:17 PM
Sage, Showanalyzer & Videoredo bobrap General Discussion 5 03-14-2006 09:48 AM
Videoredo help w/sage recording jettman General Discussion 1 03-09-2006 06:16 AM
timelines (?) in some files are wrong... JonTom SageTV Software 1 01-22-2006 12:03 PM
