Old 06-01-2010, 07:30 AM
taylormadearmy taylormadearmy is offline
Slow tuning in Sage7
Hi All,
I'm finding tuning / changing channels is far slower (between 5-10 seconds versus 2-3 seconds) in Sage7 than it was for me in Sage6. I'm using several DTV-T Hauppague sticks.
Is there anything obvious for me to try before I submit a support request?
T
Old 06-02-2010, 01:13 AM
andypitt andypitt is offline
Hi,
I am having this exact same problem using a Hauppauge PCI DVB-T Card, any feedback on this?
Andy
Old 06-03-2010, 08:52 AM
bsung bsung is offline
My HD PVR is slower too. BUT, it does seem to be more stable. Since v7, I haven't had it lock up yet. Granted, I've been messing around with things so I've been rebooting everything much more frequently.
Old 06-03-2010, 11:14 AM
Mark SS Mark SS is offline
DVBT tuning is far slower for me in the beta, often 10+ seconds rather than a consistent 1-2 in v6. I'm also seeing a black screen, without 'No Signal' message, on occasions which then results in a full UI crash when pressing stop.
Gathered logs and sample files last night, will submit a bug report tonight. Do so also as the more examples Sage have to work with, the better chance of identifying the problem and fix.
Old 06-06-2010, 03:40 PM
Thats exactly what I am seeing. Will post some logs when I get a chance. Do you know if there is any particular logs that support are after for this issue?
T
Old 06-07-2010, 02:22 AM
jamesdisco's Avatar
jamesdisco jamesdisco is offline
I'm seeing this too, sometimes a change is quick other times it can take so long the no signal comes up and then a picture appears after that.
Server: Win 10 64bit Core i3 8GB 20TB, TBS6985, TBS6984, Sage 9.
Clients: 5 x HD300, 2 x HD200, Placeshifter.
Old 06-07-2010, 03:16 AM
Make sure debug logging is enabled which will produce sagetv_<n>.log files. If you experiance UI crashes you should find hs_err files in the SageTV directory also. Copy any recordings that cause failures out of your recording directory in case Sage ask you to upload examples.
Old 06-10-2010, 04:50 PM
I found the slow reason, the stream presents a "visually impaired commentary" audio in stream description, but there is no data available. SageTV wait that audio data till timeout.
Here is an update http://download.sage.tv/users/qian/7.0.10/TSSplitter.ax.
because I don't have stream data, I*didn't test it, count on you to test.
Possible fix from sage support. Its late so I have only briefly tested but certainly improves things for me.
Let us know if it helps you..
T
Old 06-12-2010, 04:32 PM
teedublu's Avatar
teedublu teedublu is offline
uh uh,
Didn't help with "no signal" for me.
Still have a few channels that won't tune at all in Sage7b10 w/ that new (6/10) TSSplitter, and a few others that sometimes tune to the wrong channel -- so far the wrong ch is always the same wrong one. All is well in HDHR QuickTV
TW
Old 06-13-2010, 08:21 AM
Tried the new TxSplitter.ax. Every channel I tried responded with video playback error, couldn't tune any.
Old 06-13-2010, 03:32 PM
Originally Posted by teedublu View Post
uh uh,
TW
Oh dear
I trust you have filled out a support request? Do let us know what you hear back.
As I said I did not have much time to test this fix but it did seem to helped a bit.
I'll test more and submit more logs when I get time later this week.
I think I may also have seen an issue with the wrong channel beeing tuned. Which channels u seeing the issue with?
T
Old 06-15-2010, 04:12 PM
Much improved in 7.0.11, probably close to tuning speed in v6.
My wish for Sage7 or later... metapath SageTV Beta Test Software 9 06-03-2010 01:24 PM
HVR2250 slow tuning sflamm Hardware Support 0 04-11-2009 04:17 PM
SageTV Client: Initial tuning or video loading is very slow Armondole SageTV Software 1 09-24-2008 12:18 PM
Slow tuning with the SageTV Trial version spontex SageTV Software 7 08-29-2008 03:51 AM
Slow tuning with USB-UIRT / DirecTV D11 receiver mattporco Hardware Support 7 02-19-2006 09:52 AM
