Old 06-11-2011, 04:16 PM
Steerpike Steerpike is offline
HD Theater 300 as a simple extender
I've built and deployed several Sage media center setups over the years, but now my needs are simple ... I have a commercial HD DVR box (from cable provider) in one room and I want to hook up an HD TV in another room. I have ethernet in each room. So in this scenario, I have no Sage media center software anywhere, no PC, etc. I just want to take a TV 'out' signal (HDMI preferably, but RGB or DVI would probably be ok) from the DVR, and 'extend' it over ethernet to the TV in the next room, presumably using the HDMI, DVI, or composite inputs on that TV. I don't have the option to run a long HDMI cable or I would ...
Does Sage have anything in it's lineup to satisfy this need? Seems to be an easy concept but I'm unable to locate devices to do it!
I've seen that Sling have the 'SR 300' box, but that requires a 'SlingLoaded' DVR to talk to it - and that seems to be limited to Dish Network boxes.
Thanks.
Old 06-11-2011, 04:41 PM
So the TV in room #2 would just display whatever channel the TV in room #1 is displaying? No channel changing capabilities in room #2?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV & OpenDCT Dockers
Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 06-11-2011, 06:25 PM
That would suffice in the most basic configuration.
Old 06-11-2011, 06:35 PM
Monoprice has HDMI extenders available in both cat5e and wireless configurations:
http://www.monoprice.com/products/su...01&cp_id=10105
Old 06-11-2011, 06:36 PM
matt91's Avatar
matt91 matt91 is offline
how about just running HDMI over ethernet?
http://www.google.com/products/catal...ed=0CDcQ8wIwAA
edit: What he said
Old 06-12-2011, 10:05 AM
Thanks for the link. I have Cat5e cabling in place in the walls, but I don't think that would help here - the 'Cat5e' extender here is presumably using a dedicated point-to-point Cat5e cable for the task and is not compatible with ethernet signaling/etc (all my wall outlets route back to a central 'switch' ('hub') so the signal would have to traverse the switch, and thus be a compliant 'ethernet' signal). HOWEVER - the wireless version looks to be of interest ...
http://www.monoprice.com/products/pr...seq=1&format=2
Has anyone had any experience with such a device?
Thanks again!
Old 06-12-2011, 06:11 PM
PiX64's Avatar
PiX64 PiX64 is offline
How about a dish network 2 room system?
Old 06-12-2011, 07:57 PM
nebulink nebulink is offline
just because your wires run down to a switch does not mean you need to use the switch. You could add a simple coupler. this would complete the circuit and allow you to use the hdmi over ethernet option.
Old 06-13-2011, 01:15 AM
It would indeed, but - I need the availability of a network in those rooms.
Note - and I'm not trying to be too pedantic here - but the device is "HDMI over Cat5e" (or Cat6) cable, not over ethernet - if it were really 'over ethernet', it would work with the switches/etc
http://en.wikipedia.org/wiki/Ethernet
Old 06-13-2011, 04:23 AM
andypitt andypitt is offline
Do a search for just add power in google you will find exactly what you are looking for
SageTV HD Theater as Media Extender questions dinki SageTV Media Extender 6 08-17-2009 08:47 AM
Easy to hide IR extender for HD theater? Or maybe RF? kbyrd SageTV Media Extender 10 01-03-2009 04:50 PM
HD Media Extender OR HD Theater? framecrash SageTV Media Extender 2 12-13-2008 08:17 PM
Sage HD Theater of Media Extender Questions TheraEdge SageTV Media Extender 4 12-09-2008 10:02 AM
Simple Media Extender Question mike1961 SageTV Media Extender 1 10-10-2006 05:56 PM
