Old 11-27-2005, 07:20 PM
ShadoWolf's Avatar
ShadoWolf ShadoWolf is offline
Media Library Refresh timing
I've loaded over 400 ripped DVDs and nearly 18,000 mp3 tracks into my Sage Media Player using three directories speficied as UNC paths off server shares. I have no problems seeing the media, the problems arise from Sage "checking" to see that the files are still valid.
I see CONSTANT network traffic between my Sage box and my media servers, everything is running on a fully switched gigabit network, but I'm still noticing extreme "slowdowns" when Sage scans the media.
I used a network sniffer (Ethereal) to analyze the traffic to find out what was going on, and that's how I know it's Sage checking the media that's doing this. It takes Sage roughly 45 minutes to run a full scan on everything, it breaks for about 15 minutes and then starts the scan all over again. I assume this means that Sage "checks" the media every hour...
Which leads to my question: Is there a way to increase the time periods between Sage media scans? Is there a way to schedule when these scans take place? Best case, is there a way to disable the scans so they only take place if I MANUALLY start them from the setup windows (ie - only when I know things have changed?)
This is a rather large problem as the traffic is having the following effects:
1 - I get "jumps" in my SageTV recordings when the scans are taking place.
2 - The bandwidth consumption of these scans cause both my Sage box AND any other clients on my network connecting to the media servers to "slowdown" or have "skips and jumps" when trying to playback media off the servers, even though it's all FULL GIGABIT (Gig NICs, Gig Switches w/ "oversized" backplanes...)
HELP! Thanks...
Old 11-27-2005, 10:13 PM
I have never tried modifying this property, but I just saw one you could try... set:
seeker/periodically_scan_library=false
It _sounds_ like it will prevent periodic library scanning. If there is a setting for the delay between scans, I didn't notice it.
