SageMVP -black screen on video, menus work fine
Hi,
I think I managed to get nearly everything in the subject line but this is what is going on: I'm on a trial version of the extender but the SageTV and SageTV clients are licensed. Pictures, music (MP3, not WMA) work and so do the menus but video does not play. Sound does play for video but on screen only 2x floating the word trial. Is this normal? I'd like to see what the video quality is so it would be nice if it could work. In the setup there is hardly anything to set in terms of video processing so maybe it's a feature and not an error? ![]() I did notice that the screen positioning of the menu was way off but that can easily be adjusted. Jan |
When using the MVP [WRONG]try going into the Detail Setup of Sage and try the different decoders, overlay, etc until you get a picture[WRONG]. Also, did you reboot you server after upgrading to 4.1? Unplug the MVP, reboot the server and then plug in the MVP again. Good luck.
Gerry EDIT: The above is incorrect. MVP is hardware-based so none of my above decoder suggestions are relavent. All I can suggest is make sure you reboot your server after installing 4.1 If you're running the Sage service stop that and run the Sage GUi and try to get the MVP working. Then set it back up for the service. I had Matt's plugin running originally so it was much more than install and turn the MVP on.
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. Last edited by gplasky; 12-16-2005 at 12:14 PM. |
I just bought a MVP to test this out. I get the same problem, when I tune to a channel I get sound but only a black screen with the text TRIAL on two places that seems to move randomly on the screen.
I am using a PVR250 PAL version since I live in Eurpoe, I also have a European MVP with SCART. I don't have a license for the MVP but of cource my Sage is licensed. I don't have any settings for decoders or overlay on the MVP and I suppose that i should not have that since it use the built in hardware decoders. Should this work on PAL devices? Anders |
Andy,
Thanks for your reply - any idea when we Europeans can join the fun? I actually know when we can: when it is ready of course ![]() Is the SageTV client license trade-in program deadline a clue? p.s.: good thing my kids were just watching a movie on the SageTV saved me some time experimenting. Thanks, Jan |
Sorry, I don't know anything about when PAL might work; I just know it isn't there now.
Thats to bad, I just bought a mvp for this. I just have to wait then, Sage usually delivers sooner or later.
Anders |
Aloha,
i upgraded and now i have a problem. I tried the extender software and saw, that the video stays black. I was pretty sure that it is a PAL thing. Well i went back to matt's client and now it doesn't work anymore. Well is does work, but the -multi parameter does not work with the client anymore, so i am limited to one MVP. Now I do see why Sage wants a license for every mvp and actually I have enough client licenses, but that isn't helping me at all. Is it just, that I am making a mistake or did Sage actually disable the multi parameter? And is there a work-around until the PAL extender works? I don't want to go back to 4.0 because the TVTV epg service now works. I tried only reverting the client to an earlier version and it starts up but has no connection to the "server-service". Meaning I see now recordings, ... . This is a little frustrating. Marneb |
black screen
black screen stuttering sound on my mvp
very bad ![]() ![]()
Sage V7x: Server - Lenovo K320 with WindowsHomeServer2011, 10 Terabyte HD's on stablebit drivepool, (1 x DuoFlex CT Octopus PCIe DVB-C 4 Tuner all with LM-DVB-SmartRecorder, dbox2, run SageTV as Service, DeskNow Mail and Collaboration server, 2 Terabyte NAS (Ximeta) as seconf backup, 1Gb/s MSI ePower HD Network, 3xHD100, 1xHD200, 1xHD300, Panasonic LCD 55" TV, Sharp LCD TV, JVC LCD TV, Touchscreen LCD, PlaceShifter cu at http://www.dbuschek.de |
I am having the same problem in the US with no PAL. I have two MVPs and cannot get either to work with 4.1 natively. I removed and reinstalled everything multiple times and always got a black screen when trying to play a video. Menus looked fine but when trying to play a video it hangs for about 20 seconds then I get a black screen with a blue rectangle at the top which I assume is part of the OSD then after a few seconds it crashes and reboots the MVP, over and over. I have removed everything, Java and Sage and did a clean install of Sage without my old porperties file and wiz.bin (let it create new ones without any add ons) and nothing worked. Reinstalled 4.0 and Matt's client and boom, back up and running just fine. Something is very wrong with MVP support. If I were a new user ...... It's not very friendly. Will wait till I see others get this working properly. I already sent in and got two client licenses replaced so they are no good now AND the MVP doesn't work
![]() By the way, I love Sage and really want this to work cause the menus in the MVP do look nice and are snappy to navigate just no video :-) Last edited by jlabrue; 12-17-2005 at 07:50 AM. |
As I said, I totally understand why Sage did this, but it is really frustrating! As always something with PAL does not work and it normally takes quite some time to be fixed. So I would, but can't use the method prefered by Sage. This leaves me with a spare license and a mvp that is not working !anymore! As soon as the extender works I will use it but until then I really beg ![]() Please. Marneb |
Gplasky,
"I had Matt's plugin running originally so it was much more than install and turn the MVP on." What were the things you had to do? I am having the same menus work, no video, then mvp reboots problem others are having. |
I Had same problem, menus but no viedo.
Found problem was in NIC advanced settings. Had a setting called Check Sum Offload - set to enable. Changed to disable. Boom viedo and sound. Then I hab very bad shuttering and sound out of sinc. I had a USB ethernet adapter. Switched to Usb adapter. works great now. Must be a great sencitivity to NIC's Hope this helps. ![]() |
