Old 04-23-2006, 12:58 PM
pschweig pschweig is offline
Sage UI only displays partial menu on wake up from system tray
Hi
I submitted this as a bug report to sage tv - they did not give me any ideas why it happens. They suggested it was something to do with my remote setup
Originally Posted by pschweig to sage support
Fairly frequently when Sage wakes from system tray only some or none of
the options are displayed on the main menu (ie Standby might be available
but sage tv recordings, Schedule recordings etc are missing). Press up or
down on the remote brings them back.
Anybody seen similar behaviour? I am using a hauppauge remote and usb uirt.
Old 04-23-2006, 04:59 PM
amac's Avatar
amac amac is offline
Yes, I get this this too although not from the sytem tray. It happens sometimes when I just startup Sage. It just hasn't bothered me enough I guess to report it.
amac's config:
Sage 7.1.9, Java Java 1.7.0_75, Windows 8.1, Athlon X4 620, 4GB, Hauppauge 950Q, ATI 650HD video encoder with IR/Blaster, Radeon 5450, HDMI out, TV is primary monitor, Plex Plug-in serves up to mobile devices/PS3/WiiU just fine
