Old 09-22-2006, 06:33 PM
GTwannabe's Avatar
GTwannabe GTwannabe is offline
Wake system from standby with MCE remote?
Is it possible to wake the system from standby with the MCE remote and receiver? My USB ports are set to 5vsb, and I've tried switching ports with no success.
Intel NUC SageTV 7 server - HDHomeRun PRIME - 2TB iSCSI ReadyNAS storage
Intel i3 HTPC SageTV 7 Client - Win 7 x64 - Onkyo TX-674
Old 09-22-2006, 06:43 PM
blade blade is offline
I put mine to sleep every night and wake it in the morning with my MCE remote and receiver.
Old 09-22-2006, 06:47 PM
Motofreak75 Motofreak75 is offline
Send a message via ICQ to Motofreak75
you have to make sure that you set in device manager that the USB hub that has the MCE IR unit " Allow this device to bring the computer out of Standby" is checked
also check the MCE HID device aswell in device manager to. that helped me out to resume from standby.
12.04 server Sagetv7
HD-pvr / 2250 /PVR 500 / DVBS w/rotor & 36 inch dish
Old 09-22-2006, 11:42 PM
GTwannabe's Avatar
I don't have any of the power/sleep options in the device manager for my MCE receiver. Are you using the default Windows drivers, or something else? Mine shows up as "eHome Receiver" or something similar.
I checked under each USB hub, and the option box for "Allow this device to bring the computer out of Standby" is grayed out.
Old 09-23-2006, 12:05 AM
Everything you said is exactly how mine is and I'm using the regular windows driver. Are you pressing the power button to wake it? Mine only wakes if I press the power button on the remote.
I don't know if it matters or not, but all of my HID compliant devices are checked in the device manager to wake from standby. You might also check your bios to see if there is a setting in there or not.
Old 09-23-2006, 02:40 AM
Mahoney Mahoney is offline
You may need to add a BIOS key and value.
Key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usb
Value:
USBBIOSx 0x00000000 (0)
Old 09-23-2006, 06:29 AM
Polypro Polypro is offline
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usb]
"USBBIOSx"=dword:00000000
Copy/Paste, rename whatever.reg
P
Old 09-23-2006, 09:42 AM
GTwannabe's Avatar
P
Thanks, that did the trick.
