SageTV United Kingdom SageTV and SageTV Recorder Users from the UK - This forum is for you to post about specific issues using SageTV software in the UK. |
EPG Grabbers for Radio Times in UK
I'm using Alan Birtles radio times grabber to get my EPG listings but have had a few problems with it lately. I have sent a message to his forum and am sure it will be sorted, but I wondered what everyone else in the UK is using.
Alan Birtles EPG Grabber for me, it works very well/easy to cofigure +1/+2 channels.
Im sure Alan will get back to you today, normally the only issues that arise are when RT start playing around with their listings.
Abit AN-AM2HD | AMD5000+ | 2048MB DDR2-800 | ATI-3650 | 3TB Storage | Sage 6.4.8/Meedio 1.41 | XP 32BIT | FireDTV S2 | WinTV-NOVA-S+ | USB-UIRT/MX-500 Remote | Antec Fusion Case | Zalman Reserator 1 V2 | 1GB NIC`s |
You must be right, I found a command line xmltv.exe that you can use but the configuring is a pain in the neck, and that seemed to be working until
http://xmltv.radiotimes.com/xmltv/1961.dat: Code point \u0000 is not a valid character in XML at /PerlApp/XMLTV.pm line 1758 so yes, it must be the radio times website. The next thing I have to do is work out when it fails so that it doesn't copy and empty epg file into sage. I saw in some earlier documentation on his website about it returning a 0 if its successful or 2 if it fails. I have to put this into a script now to check for this. |
Yes, Birty's grabber is leaving an error in the log:
Error downloading listings: Cannot start string search from 0
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.3, tvHeadEnd for recording back end, Emby Clients: 3 Nvidia Shields, 3 FireTV, 3 Win10 Pro PC Clients |
He said on his forum that he'll look tonight.
I feel guilty when people start looking into things, I'm sat at work, bored silly, nothing to do, so I play with my pc at home. I really should find some proper work to do. If my boss walked in I'd be in for it..... |
![]() Do other people use XMLTV as well as the grabber? I thought you needed two steps, grab then run xmltv against it, will the Grabber alone be enough? If so, do you sort the output?
I used to sort it after, but then when I tried to sort it with the option in the grabber program it used to hang, so I unticked it but forgot to put the sort back in from xmltv.exe. It's worked fine since so I've never bothered putting it back!
I read somewhere that the sort makes it easier for sage to import the file, if its true or not I don't know, but it would be interesting to see what others do. |
it is a problem with the rt data. there are a couple of null characters at the end of the description for clerks. 3.06 is uploading now (over dial up so will take about 10 mins) and should be able to cope with null characters
Thanks, that's worked a treat!
![]() Do you know if there's any reason to use xmltv on the output from the grabber? Does it do anything that ticking "Sort" doesn't do?
dont think so
Thanks Birty your a star. I can't download it yet but will try tomorrow.
I've got to think of something else to do tomorrow now..... ![]() |
Hmmm, sorting seems to hang for me too...any ideas on that? I left it around an hour and was still not responding.
its pretty slow, if you leave the order set to channel,start,stop (the order the data is in anyway) then the sort will take ages. i could make it faster but cant really be bothered
If it's in that order I guess there's no point anyway! I'll give it a try...
Thanks for the great app!! ![]()
can somebody post a download link for the new version I can't seem to access
http://www.birtles.org.uk/xmltv/ I've sent birty a pm about it. Can anybody else access the site? |
Got it now.
Thanks Rick ![]() |
Top man Birty, cheers again.
Noticed that Radio Times doesn't appear to have EPG for Bravo 2. Is it a new channel or have RT never had data for it? |
@Mark SS
Its a new channel, checking the RT listings guide(http://www.radiotimes.com),RT currently seems to have no data for it. PS..You have to register to get the full listings guide.
Birtle's grabber stops working after I upgrade it!
Always always remember to tell the fire wall to allow the new version of the program to access the internet! The console version of the grabber does not tell you that it failed to access the internet and any firewall popups have long gone by the following morning. Worst of all is that you don't realise that there is a problem until 2 weeks later!
Some how, I forget this every time! I'd be dangerous if I had a brain! ![]()
Setup: - Server - Intel 3.4G D + XP, 2Gig ram, 3TB of raid. All running in service mode with 2 Hauppauge HVR4000 Running v7 with LMGestion's XMLTV and DG2XML. I also have the web server running. Client - x2 plus PlaceShifter on various machines including eeepc Ubuntu 8.04. I am streaming Live TV to my PocketPC. Stable but can use DVB-S on second HVR400. ![]() |
