SageTV Linux Discussion related to the SageTV Media Center for Linux. Questions, issues, problems, suggestions, etc. relating to the SageTV Linux should be posted here. |
DVB: Load tuning frequency data failed
Hello,
after i installed sagetv linux oem edition i managed to start the server and acces it via placeshifter. unfortunately i didnt manage to tune my Haupauge Nexus dvb-c card . In the setup process i tried to get chanel information via tvtv. Unfortunately there seems to be a bug as it didnt connect to www.tvtv.de .in the appearing screen it shows it cant connect to "www.tvtv.de,de" . or there is something missing. in the log file i got that message: tv.sage.a: kind=2; java.lang.UnsatisfiedLinkError: no tvtvDLCL in java.library.path Anyway there should be another way to get a frq file. What can i do to add my frequencies manually ? i made a channels.conf with some linux tools from rthe dvb-apps packages for xine. Can i use that data in any way ? sagetv 6 linux oem fedora core 6 thanks for your help Alexander |
It looks like DVB is not fully supported in the linux version yet despite what earlier posts may suggest. I spent a week trying to get my DVB-T card working with no luck and finally gave in an e-mailed Sage. According to Sage support currently only ATSC/QAM is supported (not totally sure where these fit into the DVB-T/V/S group) but full DVB support is on its way soon - hopefully very soon...
Quam is a modulation scheme for dvb-c. and the websitre say there is dvb-c support for linux. generally the card is recognised but i dont know how to find channels or to tune them
greetings Alexander |
