Old 05-10-2007, 02:53 PM
sg010 sg010 is offline
enable and disable channels
I can enable and disable channels for the PVR-150 (SD cable) but cannot on the HVR-950 for OTA HD.
I did a scan for available channels and there are several I want to disable, I would assume it would be the same process for the 950 as it was for the 150?
yes, I looked at the manual, read the FAQ and did a search...
Old 05-10-2007, 03:37 PM
On the Channel Setup menu, it _should_ simply be a matter of selecting the channel to toggle whether it is enabled or disabled. What happens when you select a channel?
Old 05-10-2007, 04:33 PM
nothing other that the channel gets highlighted, I was able to disable 50 or 60 channels off the 150, but I cant change the state for the channels on the 950
Old 05-11-2007, 10:47 AM
What STV are you using? If you are not using the default SageTV3.xml STV, then switch back to that one for configuration.
If you are using the default STV, then enable debug logging and contact SageTV tech support.
Old 05-11-2007, 12:06 PM
got it fixed, I removed the 950 and added it back and now am able to enable and disable channels.
thanks
The WORST "feature" of SageTV is... chrisc16 SageTV Software 21 03-30-2006 10:25 PM
Sage TV - Setup Problems mike1961 SageTV Software 8 02-02-2006 02:21 PM
Multi-Tuner One Lineup rickgillyon SageTV Software 9 12-19-2005 02:03 PM
SageTV Crashes if 350 Hardware Decoding Only set to ENABLE saclarkdoc Hardware Support 1 07-05-2005 12:00 PM
