Old 10-01-2007, 08:05 AM
Ken C Ken C is offline
HDMI or Component ???
Finally retired the 4x3 Toshiba RPTV for a Samsung 16x9 LCD. The Samsung has both HDMI and component inputs and is currently hooked up to the HTPC via component.
The HTPC has a Sapphire x1600 video card with DVI or component outputs.
The component feed looks pretty good. Would the DVI - HDMI look better ?
Old 10-01-2007, 08:47 AM
malore's Avatar
malore malore is offline
In theory HVI/HDMI is better than component because it eliminates converting the signal for digital to analog and then back to digital. If you already have the needed DVI-HDMI cable or cost isn't a factor than go ahead and give it a try. The difference probably isn't significant. An advantage of leaving it component is that you keep the HDMI input(s) free for things like HD-DVD, Blu-Ray, etc. that may require HDCP.
New tools for Studio users GKusnick SageTV Studio 206 11-29-2009 10:08 PM
VIP211 simultaneous output of hdmi and svideo? DArthur Hardware Support 2 03-04-2007 07:46 PM
Component output to TV garyellis Hardware Support 3 07-22-2006 08:27 AM
Component vs SVideo scbundy Hardware Support 10 06-06-2006 05:39 PM
Nvidia 6600GT AGP and Component out jptaz Hardware Support 10 04-08-2006 10:09 AM
