Old 12-22-2007, 08:51 AM
osburnfamily osburnfamily is offline
Question New Convert from MCE Needs A Little Guidance
Greetings all! I'm a new convert from a long-time MediaCenter 2005 build (using MCE for 3 years). I finally decided to make the leap to Sage (mainly because of the awesome PVR vs. MCE) & just bought myself an early Christmas present! (A Sage license).
Right now I'm dealing with a WAF issue. I think if I use the SageMC plugin I can get her to like Sage instead of MS-MCE; however, I can't figure out how to get the 'My Videos' section to function like MCE. I have all my shows & movies called 'TV Shows' & 'Movies'. Within the 'Movies' folder I have four ratings folders 'Rated G', 'Rated PG', etc... In each of those folders is a folder for each movie, with the movie .avi (I've transcoded my entire library to h.264). Additionally, each TV Show/series is broken down to its each series folder/season folder/episodes.avi. (See attached)
My question is, is there a 'guide' on how to setup your videos for SageMC? I guess I don't mind having to go back and "re-do" my library setup; however, I'd like to only have to re-do it once.
Thanks & I look forward to a long relationship with Sage!
Old 12-22-2007, 08:53 AM
New Convert from MCE Needs A Little Guidance - Additional Pics
Last two pics of current setup (from original post).
thanks again!
Old 12-22-2007, 10:23 PM
You may want to post the question in the SageMC thread. I have not seen a guide for setting it up, but I can tell you SageMC's dynamic menus allow you to create viewing filters based on folders. You can also sort movies by genre too.
B
USB-UIRT + MCE Remote jblaty Hardware Support 3 07-09-2007 01:52 PM
Need to Fully Disable MCE Sandbox General Discussion 1 11-12-2006 05:13 PM
Problem getting the MCE Remote Green Button to work bitbyte Hardware Support 10 05-09-2006 03:59 PM
Using the MS MCE Keyboard/Mouse/IR with SageTV. deria Hardware Support 3 04-08-2006 07:19 AM
MCE2005 = Sage 2.0 killer? rotaryracer General Discussion 45 10-27-2004 06:50 PM
