View Poll Results: Will sage benefit from multi-core, multi-cpu systems? | |||
Yes |
23 | 92.00% |
No |
2 | 8.00% |
Voters: 25. You may not vote on this poll |
Would Sage benefit from multi-core, multi cpu configurations?
Just as the title says, would you notice a big performance boost running sage on a dual quad core xeon system, say for arguments sake, 2.5ghz xeons on an Asus workstation/server board with something like 4 or 8 gb of ram?
I"ll be running 2 hauppauge pvr 150's, and the possibility of 2 HD-PVR's as well, and will be streaming to MediaMVP's (both SD and HD). Or am I better off building a single CPU system, likely with a 3+ghz quad core xeon or core-quad duo (or whatever they are called these days)? WIll sage take full advantage of that many cores. Keep in mind that this machine will be strictly a media server, for sagetv and storing other media (ripped dvd's, music, etc) |
I would do a dual-core at least(probably quad-core) for the server. Its not required, but will definitely help you out with these things:
Also, not quite sure why this was moved, as I was trying to gauge opinion rather than solve a particular problem, which is why I put it in general discussion to begin with. |
I believe all those tasks (transcoding, decoding, commercial detection) are sequential, single-threaded tasks. So more CPU cores probably won't speed up any individual task, since they're not set up to divide the load that way. (Comskip experts, feel free to correct me if I'm wrong here.)
Multiple cores will help make multiple simultaneous tasks run faster. So if you're transcoding for several clients at the same time, more cores might be a good idea. But my gut feeling is that an eight-core system is probably overkill (unless you're just looking for an excuse to spend money).
-- Greg |
Seems like quad core should be more than enough.
I'm assuming that SageTV v6 is not optimized for multi-cores. Has there been any indication from Sage if they will be considering this in a future upgrade to v6 or with v7?
My single core P4 is more than adequate for playing .avi movies and recording / watching SD TV with comskip. But since all new CPUs are multi-core now it seems like it would make sense for future versions of SageTV to be optimized to take advantage of this extra processing power.
Headless Server: Q8400 2.66ghz / MSI P45 Neo2-FR / 4GB Storage: 120 SSD for SageTV / 3TB for TV recordings / Unraid NAS 5TB for vids, pics, music w Plex Docker Tuners: HDHR3 x 2 Extenders: Nvidia Shield x2 / 3 placeshifters Server Software: Win 10 64, SageTV 9.1.5.683, Java 8_241, Real VNC Other: MiniClient, Commercial Detector UI, Sage Recording Extender |
Commercial detection is done by third party apps, so whether Sage itself can utilize additional cores or not may not be a major factor. Maybe it is when you have enough concurrent users or tuners active. I'd be more likely to go with a faster quad-core than a slower eight-core, but that's just me. |
I agree that multiple cores will definitely help. Going dual quad core xeon (8 cores) is probably overkill though
![]() Mick. |
A dual-core CPU really helps with video transcoding compared to a single core CPU. I don't know how much more performance would be gained by a quad-core. If I were buying today, with the lower prices, I would go with a 3.0 gig quad core.
If you want even more cores, can wait awhile, and pay premium prices, you could go with a six core CPU! http://www.engadget.com/2008/02/25/i...u-info-leaked/ Dave
SageTV: LIAN LI PC-K58, Gigabyte GA-EX580UD5, i-7 950 3.06 gig quad LGA 1366 CPU, Zalman CNPS9700 CPU cooler 1366 bracket, Memory 24 gigs GB, PNY NVIDIA GeoForce 9800 GT 1024 MB, Corsair 750w PSU, Samsung 500GB SSD boot, 3 SSD recording drives Capture cards: 2 - HDHR Primes - Comcast Xfinity CableTV Extenders: 1-HD-300, 2-HD-200 Software: Windows 7 Pro X64, Ghost 15, VideoReDo TVSuite 4 h.264, Playon (Netflix), OpenDCT UnRAID File Server 4.7 Pro: Lian-Li PC-G70B, MBD-X8SIL-F-O, i3-540, 16 TB |
SageTV will run transcode processes on separate threads. Depending on how many simultaneous shows you watch on MVPs (transcode)/comskip scans/whatever else you may throw into the mix should drive your decision.
B PS - Take a look at the processor requirements for comskip/SA on hdpvr files.
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
Right, but one transcoding process will not split off into multiple threads. In general it often doesn't really matter, since most dual/quad core processors are fast enough that one core can do the job on it's own (e.g. for transcoding HD for the MVP). But, it does mean video conversions in Sage are slow. Also, without a multithreaded transcoder we'll probably never see transcoding H.264 files from the HD-PVR to the MVP.
Multi Region Sage | Flatstanly | Hardware Support | 1 | 09-14-2008 07:54 PM |
Updated CPU to dual core and Sage locked my license | cenwesi | SageTV Linux | 13 | 09-02-2008 09:54 AM |
Sage 100% cpu forever after trying to use an MVP | mjrogers99 | SageTV Media Extender | 0 | 04-21-2006 08:47 AM |
Sage crashes | rfutscher | SageTV Software | 0 | 01-23-2006 04:31 PM |
90% CPU usage from sage client! | Djinn_X | SageTV Software | 4 | 01-17-2006 12:25 PM |
