Old 10-18-2008, 07:26 PM
mkanet's Avatar
mkanet mkanet is offline
Red face Quick help to change one color in "Standard HD1080" theme
I just need to know which part of theme.properties for "Standard HD1080" theme I need to change for that translucent blue to be black/greyscale with no color.
***RIP SageTV***
Old 10-18-2008, 10:16 PM
That's an image not a theme properties value. Without checking in Studio, I think it is ButtonThumbBGNormal.png.
And, I recommend you create a custom theme instead of changing any of the default theme items or else your changes will get overwritten the next time you install a SageTV update.
Appendix O in the PDF manual talks about creating a custom theme.
Old 10-18-2008, 11:08 PM
mkanet's Avatar
Hi Andy, that's not it. It just changed the color of the buttons, not the blue background that the arrow was pointing at. I tried looking through studio, but I always seem to get lost in there. Any chance you could tell me which one please?
***RIP SageTV***
Old 10-18-2008, 11:49 PM
GKusnick's Avatar
GKusnick GKusnick is offline
I'm not too clear myself on what the red arrow is meant to be pointing to. If it's the swirly background graphic, that looks like a custom image you've created. If it's the blue rectangle containing the program description, look for the following comment in Standard SDTV\Theme.properties:
# Define colors and alpha values for various color-filled areas (shape widgets)
It should be somewhere in that section.
General rule of thumb is that themes inherit from Standard SDTV, so if you can't find a property in the theme-specific Theme.properties, check the one in Standard SDTV (per Appendix O).
-- Greg
Old 10-19-2008, 12:01 AM
mkanet's Avatar
I'm not pointing to my background ...just the where the arrow is pointing to. I figured it's in theme.properties, as it mentioned in my first post. I just didnt know which exact part.
***RIP SageTV***
Old 10-19-2008, 02:01 AM
mkanet's Avatar
Can anyone figure out which part of the theme it is that blue transparent color? It seems to be used throughout an entire theme, such as in detailed info:
***RIP SageTV***
Old 10-19-2008, 06:03 AM
ToxMox's Avatar
ToxMox ToxMox is offline
I think it is more than 1 graphic you are going to have to change the actual images.
I would think the following at least:
I am 99% sure it isn't something in the theme properties.
Old 10-19-2008, 11:08 AM
GKusnick's Avatar
The button, title bar, and scroll bar highlights are images. The large blue framing rectangles that divide the screen into two or three major areas are shapes that take their colors and transparency from Theme.properties.
-- Greg
Old 10-19-2008, 11:18 AM
mkanet's Avatar
*sigh* yeah I'm not really interested in changing button colors... I just want to know which value(s) I need to change in theme.properties.
***RIP SageTV***
Old 10-19-2008, 12:10 PM
ToxMox's Avatar
Nothing you change in the theme.properties will change the color of what you want to change. They are images not shape objects. They are transparent images and therefore get most of their "blue" color from the background image showing through. So you can either change the images to be more opaque and have no color, change your background to something gray, or edit your STV and create shape objects for all the places you'd like to see this change.
EDIT: It seems that your arrow may not be pointing to where I thought it was so please just ignore this post if that is the case.
Old 10-19-2008, 12:31 PM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
I just checked in Studio. The settings you want in the theme.properties file are:
Color/InfoAreaBG
Alpha/InfoAreaBG
Aloha,
Mike
- Nikolaus (4yrs old)
Old 10-19-2008, 12:36 PM
ToxMox's Avatar
Wait a minute here. I thought your arrow was pointing to the background behind the text "Crave from CNET TV". Is that not what you were pointing to? Are you pointing to the shape behind the description? If so then MeInMaui's post should do it.
Old 10-19-2008, 12:46 PM
mkanet's Avatar
Thanks Mike!
Color/InfoAreaBG
Alpha/InfoAreaBG
Aloha,
Mike
***RIP SageTV***
Old 10-19-2008, 08:53 PM
I misunderstood what the arrow was pointing to, but Greg pointed out what to change a long time ago & his comment seems to have been ignored:
All those shape-filled colors are defined in the section he pointed out.... and he should know this since they were added at his request, if I recall correctly.
And, Detailed Info is using a different set of colors than the ones Mike pointed out from that section of the theme properties, so to change the colors in both places, you'll need to change more properties.
SageMC Theme: Foofaraw grooves12 SageMC Custom Interface 61 03-07-2009 04:40 PM
Unable to change 4 digit channels with MCE remote? m1k3g Hardware Support 2 12-12-2008 09:12 PM
SageMC 6.3.8 dflachbart SageMC Custom Interface 231 11-18-2008 12:12 PM
Cannot change channels Buggy SageTV Beta Test Software 4 12-29-2005 11:10 AM
SAGE TV - Can't Change the Channel mike1961 Hardware Support 1 12-05-2005 10:12 PM
