SageMC Custom Interface This forum is for discussing the user-created SageMC custom interface for SageTV. |
DVD (disk) playback from extender?
Is it possible to playback a disk that's loaded in the server tray from the extender (HD100)? I can go into the Videos section and choose "play other file" and play a specific .vob that way, but I'd like to be able to play the entire disk structure if possible.
This would especially be helpful for rentals that I don't want to have to rip before I'm able to watch them on the extender. And ideally, it'd be nice to be able to use the "DVD" option on the main menu to kick off playback. Anyone know if this is possible? |
Put a DVD in the drive and then add the drive as a library import directory. When you do an import scan, Video_ts will show up as a new item in the video library, allowing you to play DVD discs directly. I use this all the time.
Aloha, Mike
"Everything doesn't exist. I'm thirsty." ...later... "No, it's real!!! I'm full." - Nikolaus (4yrs old) |
Interesting. So would that mean you that have to do a rescan every time you want a new disk to show up and then again whenever you're done to remove it? What happens when you don't have a disk in there - do automatic scans basically "remove" the video_ts from the video library, or does it still show up but now it's empty?
I've got so many videos in so many different UNC folders that a scan typically takes me a good 10 minutes or so, but if automatically removes the folder on the next scan after I remove the disk, then I'll only have to manually do the scan when I'm adding a disk back in, right? Maybe that wouldn't be too bad. Any idea what it's looking for when I select DVD from the main menu on the extender? The screen turns black for a while like it's going to try to play something, but then it just throws an error eventually. |
Err... just tried this, and I got a really weird problem. Instead of an item in my video library showing up named video_ts, I got two new items - both other dvds that I have in other import directories. Except they're showing up at the top level instead of in the folders they should be in. ("Boys Don't Cry" and "Goldeneye") The DVD I have in the tray is a home burnt dvd of home movie footage.
Even weirder: if I try to play Boy's Don't Cry, it plays fine (even though it's showing up in the wrong place). If I try to play Goldeneye, it actually plays the DVD I have in the tray. Any ideas? |
Scott
Server - Intel Pentium 3.2 - 3 GB RAM - WinXP SP3 - Headless 80GB system drive - 500GB Recordings - 2TB NAS (1) HVR-2250 Analog Cable & Clear QAM (1) HD Homerun clear QAM (1) KWorld 115 ATSC Tuner OTA (1) HD200 HDMI to Samsung 50" Plasma (1) MediaMVP to 19" in bedroom SageTV 7.0.23 release |
Correct, encrypted DVDs can't be played by the extenders.
I usually play encrypted DVDs on the extender using DVD43 on the server. It normally works fine.
Gian Piero |
He was giving the company line, he very well knows there are hacks that allow all sorts of stuff.
It's a factual statement. The Sage extenders can't play Encypted DVDs. It's as simple as that. There are ways to make encrypted DVD appear to be unencrypted, but discussion of that is not terribly well tollerated here.
Do you also set the drive as an import directory and do a scan of it when you put in a new disk?
SageTV V6.5.5 Release Candidate is Here! | Narflex | SageTV Beta Test Software | 0 | 12-23-2008 12:01 PM |
How good is DVD iso playback ? | Kryspy | SageTV Media Extender | 3 | 12-13-2008 01:02 AM |
DVD playback from hard drive | phongshader | SageMC Custom Interface | 0 | 12-07-2008 12:20 PM |
DVD playback On HD Extender | viperdiablo | SageTV Media Extender | 3 | 06-16-2008 08:23 AM |
