Old 08-10-2009, 04:16 PM
tvmaster2's Avatar
HD Theater and DVD playback
I'm just guessing here, but from what I understand, the HD200 doesn't play DVD's (if you have a DVD drive in your Sage server), but instead CAN play VOB files from a folder directory?
Old 08-10-2009, 04:18 PM
Brent Brent is offline
The HD200 can play ripped DVDs (vobs and such in a folder) from your server.
It can also play streamed DVDs from your server as long as the DVD doesn't have DRM on it or the DVD is "tricked" into thinking it doesn't have DRM with AnyDVD.
Same answer for Blu-Rays as well.
Old 08-10-2009, 04:24 PM
tvmaster2's Avatar
Great, that's what I thought. But it absolutely won't fire up the DVD player/burner and spin a disc?
Old 08-10-2009, 05:13 PM
If you add your DVD drive as an import directory and have something running to decrypt the disk, yes you can play DVDs right out of the drive.
But no, there is no "Play DVD" option, and it can't play encrypted DVDs.
Well, that assumes you're running in extender mode (in which case your post is in the wrong forum ). In standalone mode, that's a good question, the extender may see a directly-attached DVD drive, but even if it does, it would only play unencrypted DVDs (home made or the rare retail disc without CSS).
Old 08-10-2009, 05:25 PM
tvmaster2's Avatar
I've literally just hooked up the HD200, so I'm not yet sure if I'm running in extender or standalone mode. When I figure that out, I'll let ya know. Thanks for the info. PS - where do i find info on standalone / extender mode - the Sage manual?
Old 08-10-2009, 05:31 PM
http://forums.sage.tv/forums/showthr...74&postcount=4
Old 08-10-2009, 05:41 PM
tvmaster2's Avatar
definitely in extender mode. BTW, what's the most common thing that causes it to lose communication (mine just did)?
cheers
DVD/Movie functionality HD Theater vs. SageTV PredatorVI SageTV HD Theater - Media Player 3 04-22-2009 09:11 AM
DVD Playback iguana SageTV Software 4 09-20-2005 10:31 AM
DVD Playback pdxcoop General Discussion 0 08-21-2004 09:40 PM
Any DVD s/w for playback of DVD with DTS pass through and Hauppauge remote support?? davedelite SageTV Software 7 04-12-2004 04:48 PM
