Old 10-12-2009, 12:30 PM
Dingdul Dingdul is offline
Managing SageMC across multiple HD200s
I've produced my target customisation using an HD200 and now wish to migrate menu structures, layout etc to other units in the house. Are there any simple steps available to do this as thus far I've only succeeded in accessing the list of reworked main menu options by loading the XML file on the other units. Any help appreciated!
Old 10-12-2009, 12:44 PM
PLUCKYHD PLUCKYHD is offline
sagetv\sagevt\clients folder will have the xml saved. You have to find the on you want (probably the largest) and copy it out of the folder and back in with the same name (mac address) as your other clients.xml in that folder.
Old 10-12-2009, 12:46 PM
If you did all the configuration from the HD100 then all you need to do from each HD200 is load the sagemc_menu.xml (or whatever you renamed it) on every HD200 and load the same sagemc_169-x.xml that you original HD200 is using. Where x represents the number of plugins loaded. Sage increments the number automatically each time you load a plugin. So it could be, for example, load sagemc_169-6.xml at each HD200. Now they should all loook and act the same.
Old 10-12-2009, 07:33 PM
briands briands is offline
I don't think this will necessary pick up all of your settinge. For instance, my extenders use the same STV, but I have the fonts larger on one of them (and a different weather setting on the menu) since it is used on and SD tv.
You will also need to go to the Sage MC options screen and back up the Sage MC options and also need to save the menu file.
Old 10-13-2009, 04:18 AM
Correct. Font settings are stored in the .properties files. So if there are other .properties specific settings you would probably need to copy and rename. Most plugins will write their settings to the client's .properties so you may need to configure a plugin after choosing to use a common .STV. For me I only have to copy the Movietimes plugin settings because you really can't configure it from a client. And I don't change font sizes so I had no need for that either.
HD200s no auto log-in MrVining SageTV HD Theater - Media Player 11 09-29-2009 10:46 PM
Need Hardware Advice - New Server for transcoding vs. more HD200s bcloud Hardware Support 5 09-04-2009 09:05 AM
DHCP not addressing HD200s, need help najames SageTV Media Extender 18 07-15-2009 09:05 PM
Managing favorites garyellis SageTV Software 3 10-02-2006 09:27 AM
Manually managing recordings cclayton SageTV Software 3 10-06-2004 09:57 AM
