Old 10-23-2009, 03:15 PM
skiingwiz skiingwiz is offline
Arrow STV Import: Enable/Disable Favorites
Download Link | Default STV version
This import allows series favorites to be enabled and disabled without removing them. It adds a button to the Series Settings screen that will either enable or disable the series (depending on the state that it is currently in).
On the Series screen, disabled favorites will be shown in red (transparency and color are properties). From this screen the record button will toggle the highlighted favorite's enabled/disabled status.
How it works: When a favorite series is disabled, "DisabledFavorite" is added to the end of the category for that favorite. Enabling the favorite removes that string. This import also hides the "DisabledFavorite" string if it is present.
Old 10-27-2009, 07:31 AM
sic0048 sic0048 is offline
Nice work. Any thoughts about creating this for the standard STV?
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 10-27-2009, 06:02 PM
I'll take a look. It should be pretty straightforward to make the same changes in the standard STV.
Old 10-27-2009, 07:27 PM
It wasn't hard at all. Check it out:
Download
Forum Thread
Old 11-07-2009, 12:23 PM
voorhees voorhees is offline
skiingwiz, very nice enhancement. Thanks.
Server: OS: MS WHS v1; MB: GIGABYTE GA-EP45-UD3R; CPU: Intel Q9400 2.66GHz; RAM: G.SKILL 4GB (4x1GB); HDs: 1x80GB, 7x1.5TB; Graphics: EVGA GeForce 9500 GT 512MB
Capture/Content: HD-PVR, 2xHDHRP (CC), Comcast
STBs (Controllers): RNG110 (Firewire ChCh)
Clients: 2xHD300, 2xHD200, 2xPS, Client
SageTV/Plugins: v7.1.9, SageDCT, SRE, Comm Det, Jetty, Web Server, Mob Web, PlayOn, E/D Fav, Fav Ex, MF Stop, Enc Names
Old 11-07-2009, 02:24 PM
You're welcome. I'm glad that it's useful for others.
STV Import: Anti-Favorites dflachbart SageTV Customizations 151 08-29-2010 08:49 AM
STV Import: Enable/Disable Favorites for Default STV skiingwiz SageTV Customizations 2 11-07-2009 04:32 PM
enable and disable channels sg010 SageTV EPG Service 4 05-11-2007 12:06 PM
STV Import: Enable Dscaler for Sage MPEG decoder (v1.1 17/Jun/2005) nielm SageTV Customizations 9 06-20-2005 08:12 AM
Event code to enable/disable PVR 350 TV-Out? GrayGh0st Hardware Support 1 06-28-2004 08:31 PM
